Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-03-2011, 12:52 PM
Spartan Spartan is offline
Vehicle: 2011 Ram 1500
Spartan is on a distinguished road
Default A/C mod & heater core bypass
I want to make the air conditioner in my 2011 ram colder. Living in an area with heat indexes at 100+ degrees in the summer months, the typical car or truck A/C just can't keep up. In a previous truck I had I by-passed the heater core with a vacuum actuated valve. The valve would open & closed when the a/c was turned on or off. In my last truck the mod dropped the air temp at the vents between 5-10 degrees. I'd like to install the same valve in my new truck, but I need to find out if the blending door that opens & closes when the a/c is set on normal or max is controlled by a vacuum actuator or an electric actuator. AND I will need to know which heat hose line flows towards the heater core.
Thanks,
Spartan
Old 07-07-2011, 09:01 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
a/c, by-pass valve, elect, heater core, vacuum
Heater Core Replacement Dalton Heating & Cooling 1 02-05-2011 10:10 PM
Hi ! Question about the heater core! MissRam Heating & Cooling 3 01-06-2011 02:54 PM
Heater Core replacement question jljohnson1170 Heating & Cooling 4 01-06-2011 10:25 AM
Big Bang after heater core job Quiet Lunatic 5.9L V8 Specific Topics 5 12-31-2009 06:19 PM
Is this a heater core leaking? over2land V10 Specific Topics 10 07-15-2009 11:56 AM
