Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 07-03-2011, 04:28 PM
adventurer's Avatar
adventurer adventurer is offline
Vehicle: 2010 Ram and 2006 Ram Hemi
Trim Level: 4x4 SLT and4X4 SPORT
Color: Silver , Flame Red
adventurer is on a distinguished road
Send a message via Skype™ to adventurer
Default Front shocks ???
Hi all , am new to Ram trucks so i noticed that my 06 4x4 bounces from the front more than the chevy and the ford and i didnt have a chance to check other ram truck so some people say that i have to change the front shocks and some say that no changing until they leak !! i have no leak and some times not always i hear a sound from the front driver side when i go over a ramp , any help please regarding of when to change them or how i will know that they are not working properly ?? (when the truck is parked it not easy to make it bounce from the front)
2010- S&B CAI/87MM TB/HKS TB GW/OIL FILTER BREATHER/Y PIPE/PYPES VIOLATOR MUFFLER/HEMIFEVER TUNE.
06- MAGNAFLOW CAT-BACK/Y PIPE/TB SPACER/HKS-TB GW/MOPAR CAI/SUPERCHIPS/OIL BREATHER FILTER/JET 180 TSTAT/3.92 LSD
Old 07-07-2011, 09:04 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I replaced my stock shocks on my 2006 at 80k miles. Put on a set of Bilsteins and was happy I did, better handling and eliminated some of the bounce of the older shocks. I'd like to invite you to join our Red Ram group, link is in my SIG.
Old 07-09-2011, 09:28 AM
Digipenguin's Avatar
Digipenguin Digipenguin is offline
Gender: Not Specified
Vehicle: 2006 Ram 4WD
Trim Level: SLT Sport
Rep:81
Digipenguin will become famous soon enough
Redram,
I'm at 85k and need to replace my shocks. Did you use a spring compressor?
Do you know of any howtos? I have the Chilton's book and it says to use a spring compressor but looking at the truck it looks like you can do it without one. Thanks.
It was on fire when I got here.
Old 07-19-2011, 06:51 AM
BooBear185's Avatar
BooBear185 BooBear185 is offline
Vehicle: 2004 Dodge Ram 1500
BooBear185 is on a distinguished road
I have an 04 with the original shocks on it, can anybody beat that one???? LOLOLOL!
Needless to say they will be replaced soon.
Old 07-19-2011, 08:28 AM
adventurer's Avatar
thats great , how many miles on it ? and does it bounce more than the chevy and ford trucks from the front ?
Old 07-21-2011, 05:28 PM
ike43's Avatar
ike43 ike43 is offline
Vehicle: 2006 1500 4x4
Trim Level: quad
ike43 is on a distinguished road
install bilstein 5100 struts, you can level or leave stock height, either way they will eliminate almost all the bounce and better cornering . make to have the frt end insp and alignment a must , good tires and proper pressures also helps. Iijust rebuilt my complete frt end with bilstein 5100s and mickey thompson atz, 285/70/17. hugh difference !!
Old 07-24-2011, 07:13 PM
BgHrn BgHrn is offline
Vehicle: 2006 Dodge Ram
BgHrn is on a distinguished road
Lets see some pics!
06' Ram, molding!, In-channel visors, 3" Mag' SI/SO 18" long, Mag' y-pipe, 2" HBS Leveling kit/1" rear block ,DSP 91 tune, KN CAI kit, BFG 285/65r20 rubber.
Old 08-03-2011, 12:27 AM
pankster pankster is offline
Trim Level: SLT, Quad cab
Color: Blue
pankster is on a distinguished road
Wow, maybe I should have read this forum before I bought these Monroe front struts.... They were supposed to be "premium" ones but the bounce is still noticable. My right front strut was leaking but after I replaced both front struts the bounce makes me nausious! Is it really the struts that cause the small short bounces? Going over big stuff is not issue, but the small bumps on the road cause the truck to oscilate quite a bit. I've read on some posts that it could be the drive shaft balancing... thoughts? Was gonna post another thread, but this could answer it. I'll post some pics of the install as I replaced the rack and pinions as well.
Oh, and I just got new rubber on all four corners and just did a front wheel alignment, still bounces....
Old 08-03-2011, 12:42 AM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:215
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
BooBear, I think I got you beat... I got a 97 with original shocks, worn completely out and the covers are even rusted away at 275,000 miles...lol My truck needs shocks bad, I replaced all my tie rods which were original as well, it handles better but still bounces excessively on bumps. I am just trying to figure out what are the best shocks and i need tires as well.
Mike
Old 08-03-2011, 12:56 AM
Color: Blue
some pics of my install:
Getting ready to pull the upper ball joint out to get at the strut
New Rack and pinion ready for install
Theres the leaky front right strut
The bolt holding the strut in place on the top of the spring was rusted solid and we didn't have the right tool to hold the "piston" part in place, it was a pain to get both out. But we managed....
Fun job except for this bouncing now.... Will check the drive shaft for the welded weights, see if they came off at some point.
2006 vibration 55mph rake1 Suspension 41 03-07-2014 07:52 PM
DIY Front Shocks (Bilstein) Eurotrash 2011 Dodge Ram Forum 1 06-18-2011 12:33 AM
Need Help with Shocks!!! jpaul51 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 12-05-2010 12:40 AM
shocks and 3 inch front spacers ape stit Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 08-24-2010 09:16 PM
Extended front shocks...Ranchos? 04RAMsprt Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 06-28-2010 10:16 PM
