Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 08-06-2011, 09:18 AM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
Did you have any problems getting the lower strut bolt out? Mine seems seized in the bushing. We tried hammering & even using a puller to push the bolt out, nothing worked. I'm wondering if the lower control arm is holding pressure on the bolt, maybe my control arm either need jacked up or down more to free it up.
The bolt doesn't turn in the bushing !
It's a truck, not a cream puff
Old 08-06-2011, 12:39 PM
BgHrn BgHrn is offline
Vehicle: 2006 Dodge Ram
BgHrn is on a distinguished road
The bolt is probably seized in the steel sleeve, within the bushing. Get out the torch!
06' Ram, molding!, In-channel visors, 3" Mag' SI/SO 18" long, Mag' y-pipe, 2" HBS Leveling kit/1" rear block ,DSP 91 tune, KN CAI kit, BFG 285/65r20 rubber.
Old 08-06-2011, 12:42 PM
06 BigHorn's Avatar
Rep:153
If i heat it up & get the bolt out. Do you think the bushing is screwed?
Is the sleeve seperate from the bushing?
I just picked up new bolts, nuts & bushing
Old 08-06-2011, 12:49 PM
Are you replacing the strut? If so, it won't matter if you damage the rubber bushing, right?
Old 08-06-2011, 12:55 PM
06 BigHorn's Avatar
Rep:153
Yeah I have a pair of Monroe quick struts I'm trying to put on.
Really worried about getting the new bushing in the control arms
Old 08-06-2011, 01:09 PM
hifiwest's Avatar
hifiwest hifiwest is offline
Vehicle: 2003 RAM 1500 4x4
Trim Level: SLT Quad Cab
hifiwest is on a distinguished road
I've got 230000kms on mine with factory shocks. I have a load in the bed often and can't afford to go with 4 new bilsteins, thoughts on shocks in the 35-50 dollar range? KYB's??? Skyjackers? I want this truck to be stiff as possible for the money. Stiff stiff stiff.
Gotta wreck some stuff to make some stuff.
Old 08-06-2011, 05:02 PM
Ok, then i wouldn't be too worried about the old rubber bushing. When installing the new one, maybe put some type of lube on the bushing to help it along. I've even used Dawn dish soap, like when mounting tires,etc. You'd be suprised, lol.
Old 12-28-2012, 09:49 PM
Bcun10t Bcun10t is offline
Vehicle: 2007 dodge ram
Trim Level: Slt
Bcun10t is on a distinguished road
Front struts. Not front shocks... Shocks are in the rear. BTW Rancho has pre loaded strut and spring. You don't need a spring compressor and it levels the truck.
2006 vibration 55mph rake1 Suspension 41 03-07-2014 07:52 PM
DIY Front Shocks (Bilstein) Eurotrash 2011 Dodge Ram Forum 1 06-18-2011 12:33 AM
Need Help with Shocks!!! jpaul51 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 12-05-2010 12:40 AM
shocks and 3 inch front spacers ape stit Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 08-24-2010 09:16 PM
Extended front shocks...Ranchos? 04RAMsprt Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 06-28-2010 10:16 PM
