Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-04-2011, 03:41 PM
Alfisto Steve Alfisto Steve is offline
Vehicle: 2000 Dodge Ram 1500
Color: PRV
Alfisto Steve is on a distinguished road
Default Where is vacuum tank for a/c doors?
Dash A/C doors close under acceleration. Must have a bad connection or check valve for vac tank.
Where is vac tank is it under dash?
2000 Dodge Ram 1500 SLT 5.2L
Old 07-04-2011, 03:57 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Mine is located under the drivers side of the dash behind the ABS control box just to the right of the gas pedal and up. Silver barrel looking thing with an accutator hooked to the flap. My plastic connector broke so i need to figure a way to fix that. But thats where it is at........
Mike
Old 07-04-2011, 10:54 PM
sonocativo's Avatar
Rep:210
Here it is,I assume this is what you are looking for?, I need the plastic thing the accutator goes to if anyone knows the part number/name and where to get one?
Mike
Old 07-05-2011, 08:07 AM
Color: PRV
Thanks but, that is vacuum actuator for doors not vac storage tank and check valve which keep it open (retracted) so when under engine acceleration when engine vac falls off and that spring loaded actuator will not slam a/c air flow doors shut.
Maybe there isn't a vac tank and just check valve in vac line near firewall is bad?
TURNS OUT VAC CHECK VALVE INSTALLED BACKWARDS NEAR ENGINE FIRE WALL. Easy fix just reversed it!
Old 07-07-2011, 12:17 PM
Color: PRV
Default Replaced Check Valve by buying Hose and Valve assembly
Had to just spend 15.93 to get the check valve by buying new 55055705AB vac hose and valve assembly.
BUT now the a/c doors in dash stay open under heavier engine accelerations.
Cheap fix!
Old 08-07-2011, 11:39 AM
ohio45344 ohio45344 is offline
Vehicle: 2001 Dodge Quad cab Long bed
ohio45344 is on a distinguished road
Default 55055705ab
Dealer says this is for Cruise control, does it control both? Also was it located in the engine compartment?
Old 08-30-2011, 11:35 PM
ERICG1 ERICG1 is offline
Vehicle: 1999 Dodge ram 1500
ERICG1 is on a distinguished road
I would like to know the answer to those questions as well. Thanks
Old 09-15-2011, 05:12 PM
rambob's Avatar
rambob rambob is offline
Vehicle: 2001 Dodge Ram
Rep:31
rambob is on a distinguished road
I have this same problem, what was the fix? can you post pictures of the location?
Well I woke up Sunday morning,
With no way to hold my head that didn't hurt.
Old 09-16-2011, 05:52 AM
Color: PRV
OK, guys sorry for not reading your questions sooner. As for check valve and hose assembly I listed part number above. It is hanging off front of firewall just to right of centerline over right head area.
Tubing may also go to cruise control and check valve may help crusie control actuator maintain vac under engine accel but it also hold vac on dash vents.
Old 09-16-2011, 05:16 PM
rambob's Avatar
Rep:31
found this...
there are two check valves
Fuel Fill Nozzle Shuts Off RamTech Dodge Ram Knowledge Base 3 11-22-2013 10:22 PM
Adding a spare diesel tank. casper5280 Cummins Diesel Specific Topics 3 01-31-2012 07:32 PM
Remote not unlocking doors? Big Daddy 2009 Dodge Ram Forum 5 01-26-2010 08:32 PM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 11:38 AM
Gas Tank and DTE jayhkr Body & Interior 6 05-16-2009 11:58 AM
