timing chain replacement - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-04-2011, 04:29 PM
2kram 2kram is offline
Vehicle: 2000 ram 1500
2kram is on a distinguished road
Default timing chain replacement
hello all noob here. ques. i have is how involved is it to change a 2000 ram 1500 5.9l timing chain?
Old 07-04-2011, 05:08 PM
Welcome to the forum. Not a hard job. You'll want to make sure you mark your timing gear so it's oriented properly. Check your old and new chain for a corresponding reference mark.
Basically, it's all at the front of the engine. Access with the radiator in place is very tight. Frankly, going through the front with the radiator gone is the easiest way to get this done.
Good luck!
Oh, it will save you a lot of time and confusion if you get a service manual. I got mine off eBay in a .pdf format on a CD for about $15.
Old 07-04-2011, 05:25 PM
thanks 4 the response. while thumbing thru manual should i just replace front gasket @ the front of oil pan? i figure if i have to loosen 2 front pan bolts i prolly should replace (155,000mi) it. my luck i will have problems if i don't.
Timing Chain Slack 4.7L kevinph 4.7L PowerTech V8 Specific Topics 24 03-19-2011 08:44 PM
Double roller timing chain? kicknjeep Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 8 01-15-2011 07:22 PM
Any mtc required for timing chain? Turbovsix 2010 Dodge Ram Forum 6 09-09-2010 12:43 PM
what is the dealer time for a timing chain case inner gasket change ape stit Cummins Diesel Specific Topics 5 05-26-2010 10:28 AM
Timing Belt Replacement Schedule on 2001? whitehme Dodge Ram Detailing and General Maintenance Forum 2 05-25-2009 05:49 PM
