Old 07-04-2011, 05:34 PM
tm01 tm01 is offline
Vehicle: 2001 raM 1500
tm01 is on a distinguished road
Default going to add fuel and a match if i cant fix this problem.
Well Ive been beating my head against the wall trying to figure this trucks problem out. It runs really rich and gas miliage is severely off. It idles really rough if at all and anywhere between idle and 2000 rpms is rough and seems to have a miss after 2k itll smooth out. yesterday i took it for a very short ride and had the gas pedal to the floor and it only revved to 3k rpms. the trucks and 01 with a 5.9l 4wd .
The only code im getting now is P1282 but ive swapped fuel relays and im getting the same voltage at the pdc as is in the battery in the 30 and 87 port. Im just going to list what ive done and checked. fuel pressures at 45 psi, new timing gears and chain set, recent plugs, wires, cap and rotor, intake and plenum gasket set, new coil, new map sensor, new iac. Also the head gaskets are good and not burning oil and theres no vacume leaks. I tried replacing the ecm with a new one but the one i got was garbage and give me error p0601 which is internal controller failure. Its being sent back tom. My old pcm is only giving me the one p1282 code now after changing all those other sensors.
It has spark on all wires but seems to be loading up causing idling issues. the idling issue gets progessively worse the longer it runs. The cat seems to be fine, no rattling and there is a good amount of exaust flowing out. Its almost as if the injectors are just always shooting in gas. any help would be greatly appreciated.
Old 07-04-2011, 06:08 PM
M n M M n M is offline
Trim Level: ST 1500 Quad Cab
Rep:79
M n M will become famous soon enough
Have you checked the fuel filter? Maybe you have a partially clogged filter. What about the fuel pump? Could it be running intermittent. But if that was the case I guess your fuel pressure would drop.
Old 07-04-2011, 10:10 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Don't know if this will help. Good luck.
http://engine-codes.com/P1282.html
http://www.justanswer.com/dodge/4qgo...gh-within.html
Old 07-04-2011, 11:19 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:215
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Have you checked the throttle TPS ? Sometimes that causes some crazy stuff with the way a vehicle runs. Have you checked for vacumme leaks as well?
Mike
Old 07-12-2011, 10:57 AM
Well i left the truck alone stepped away from it for a week and I think i've found the problem. Im pretty sure that i either have bad head gaskets or a cracked head. I pulled the #8 plug and it was soaked with coolant just basically looked like a huge drop that covered the entire plug. This was the first time i encountered that yet theres still nothing in the oil. so guess i just need to tear it down and find out what needs to be replaced.
Old 07-12-2011, 10:51 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
you can never be too sure that your cat is not clogged, ive come accrossed this many times and it was a clogged cat. the origional cats on these if it is origional arent very good lets just put it that way.
BEAT the crap out of it with a hammer and dont be nice about it either then take it out and floor it a couple times see where that gets you.
plus there is no fuel filter on these trucks its internal on the pump so you cant change them.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 07-17-2011, 12:53 AM
atvfamly atvfamly is offline
Vehicle: 1999 Dodge Ram Sport
Color: Banana
atvfamly is on a distinguished road
I had a problem with my 99 ( 5.9 4wd ) that was driving me nuts. When I would first start it, it would run great. But then as it warmed up, I would have to throttle it up to about 2k on the tach. Once the temp guage got up to normal operating temp, I could let off the throttle and it would run fine. If I tried to run the truck before that, forget it. I replaced everything coolant related, it was due, and the O2 sensor before the cat (upstream). Pretty sure it was the O2 sensor that fixed the problem. Maybe try that.
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
Fuel supply Problem SolidRam 5.9L V8 Specific Topics 3 03-25-2011 11:57 PM
SS/T Problems round 2 98sst Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 48 01-11-2010 07:54 PM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 10:38 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
