Old 07-04-2011, 05:43 PM
caseykerner caseykerner is offline
Vehicle: 2011 Dodge Ram 1500
Rep:88
caseykerner will become famous soon enough
Default Sport Hood LED Mod
So, I have seen some interest in how to do the whole LED's in the fake vents on the sport hood so this is my attempt at a tutorial. I didnt take many pictures with the thoughts of doing this so I apologize for the lack of quality/detail in the pics. I do have some that show the key points of what you will need to do. I ordered 50 5mm super white LED's off ebay from Hong Kong ish for about $10 bucks that were pre wired for 12v applications. This is a lot easier as well because it gives you about an 8" pigtail to work with for wiring. I thought about making up a circuit board for this project but decided to take the easy way out and see if I like them first.
First, remove the vent inserts in the hood. This is accomplished by pulling the heat shield down under the hood to gain access to the bottom of the vents. The vents are held in with 2 pressure tabs on locking lips on the vent. Carefully pull down under the hood on the tabs/pushing down on the hood in front of the vents to free the clips. Once you see it, you will understand.
The plastic vents are not too thick so minimal effort is required to drill the holes. I used a drill bit just big enough to allow the wires to be routed through and that was it. Only drill the full size honey combs, the LED's are too big for the smaller ones. Once you have all the holes drilled, begin placing the led's in the holes and secure them how you see fit. I used the wife's hot glue gun, easy to peel off and if I need to replace one I can do it without much effort to remove the bonding agent. 2 part epoxy could do the trick, just gets hard and messy. Organize your wires so all positive leads are facing one direction and negative the other. This makes it easier to wire. Once you have them all secured to the vents gather all the wires up and combine them into one lead. Repeat for the other vent and then combine your wires and hook up how you like. (headlights, blinkers, aux switch) How you choose to run the wires, connect the wires and seal the wires should be no problem for you if taking this project on. If you dont know what to do, dont try. The pictures will give you more information than the words will, so build your plan and have fun. If you have any questions just ask.
KC.
Old 07-04-2011, 05:50 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
No that is cool. Wish I had the sport hood. I would be doing the same thing.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 07-04-2011, 05:57 PM
Rep:88
Thanks! I like it a lot.
Old 07-04-2011, 05:59 PM
Rep:4072
That just looks sweet, nice job on that!
Old 07-04-2011, 07:37 PM
bigred0603's Avatar
bigred0603 bigred0603 is offline
Vehicle: 2005 Dodge Ram 1500
Color: BLUE
Rep:38
bigred0603 is on a distinguished road
Wow that looks really good congrats
Old 07-04-2011, 07:41 PM
gingrbredman's Avatar
gingrbredman gingrbredman is offline
Vehicle: 2011 Ram 1500 Crew Sport
Color: Deepwater Blue
Rep:89
gingrbredman will become famous soon enough
I appreciate the ingenuity of this, as well as the shear time it must have taken to painstakingly drill all those holes, hot glue in LEDs and wire it all up.
Did you use all 50 LEDs and how do you turn it on, or is it on all the time?
Gusz 2011 RAM SPORT CC -Lockpick CHR550 -Hardwired Radar Detector - Custom Trailer Cam - -Fold a-Cover G4 - Bed Rug - Billet Shifter - Debadged - 18" Magnaflow - Custom Clear HID Projectors - LED Tailgate Bar - Custom Billet Badges -
Old 07-04-2011, 07:43 PM
jshields's Avatar
jshields jshields is offline
Vehicle: 2011 Ram 1500 Crew 5.7 Hemi
Trim Level: Chrome Appearance
jshields is on a distinguished road
That looks great and good job turning something into nothing. I would advise though, depending on the laws in your state to avoid any of the emergency colors blue, red and so on. Did you install a switch to turn just those lights on/off? That would look cool at night with just those lights switched on....would make people be like...whoa!
Old 07-04-2011, 08:19 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
I have never wanted the sport hood until now! Awesome mod!
Big Red my old 2011 Sport
Old 07-04-2011, 08:53 PM
dwadestrick's Avatar
dwadestrick dwadestrick is offline
Vehicle: 2011 Ram Crew Cab 4x4
Color: Deep Water Blue Pearl
Rep:85
dwadestrick will become famous soon enough
Send a message via Skype™ to dwadestrick
Dang! I hate I saw this!.. Now I want to do it. It looks great. I wonder if this would fall in line with having to many lights on while driving. Cause from the pic, it looks like you have six lights on.
Factory:
Break controller, Mopar Chrome Tubular Side Steps, Sprayed in bed liner.
Changed:
Bak Flip F1, Performance Hood, Remote start
Old 07-04-2011, 09:34 PM
kewlguy53403 kewlguy53403 is offline
Vehicle: 2011 Dodge Ram Sport
Rep:25
kewlguy53403 is on a distinguished road
Oh man, added to the list :P That looks great man! What did you wire them to / how did you wire them?
Raptor Step & Bed Rails | K&N | BakFlip HD | Halo Proj. LIghts | Recon Brake Lights | DDM HIDs | Big Rig Lights | Night Raider Taillight Bar | Volant CAI | Magnaflow 18 | MGP Caliper Covers | Lower Billet Grill | 20% Tint | Blistein 5100 @ 2.8 | 34" Tires | Dipped Chrome
Underhood lamp with sport hood? abpelch Body & Interior 99 12-17-2014 09:35 AM
Dodge Ram Sport Hood darenspoon 2010 Dodge Ram Forum 16 12-09-2013 05:05 AM
Sport Performance Hood Question Bighert3rd 2011 Dodge Ram Forum 15 03-10-2013 11:03 PM
Replacing hood with aftermarket or sport hood. 2010DodgeRamSport 2010 Dodge Ram Forum 14 02-14-2012 01:28 PM
Sport Hood Chris11Ram 2011 Dodge Ram Forum 24 07-02-2011 06:55 PM
