tonneaucovered.com
Old 02-23-2012, 05:44 PM
joeAEKDB's Avatar
joeAEKDB joeAEKDB is offline
Trim Level: Demon
Color: Mango Tango Pearlcoat
Rep:520
Originally Posted by RedRiverRam View Post
1) installed just the center row of LEDs
2) used red LEDs
I have just the center row filled with the orange LEDs. Nine of them on each, in case anyone was wondering. And I'm 100% positive that red is illegal.
I have actually been pulled over already since having done this mod, and the cop didn't say anything about the LEDs at all. (Other than they looked good) Just pulled me over for my license plate frame...
Old 12-05-2013, 02:36 AM
rammin2013's Avatar
rammin2013 rammin2013 is offline
Vehicle: 2013 Dodge Ram 1500
Rep:37
rammin2013 is on a distinguished road
Casey, check this out. I found this on superbright led. Do you think this would work out well?
www.superbrightleds.com/cat/through-hole/.
I know theyre a little spendy! Especially if I wanna get enough for the whole project at once. The only thing I am wondering is do you think that I will run into an issue on the back of the scoops with the parts that hold them in place?
Old 12-05-2013, 12:39 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Make sure you get LED lights that are waterproof with an IP Rating of 65 or above. Moisture will kill LED lights quickly.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 12-05-2013, 09:31 PM
rammin2013's Avatar
Rep:37
Greg
Thanks for that.. I didn't even think to look if they were waterproof or not. what is the IP rating?
Old 12-06-2013, 12:36 PM
gcscott's Avatar
Rep:1043
A sort of simple explanation of water and dust proofing. Waterproof LED lights come in IP-65 thru. IP68
http://support.automation.siemens.co...rd&viewreg=OST
IP. The first digit-6- Wire protection dust-tight. (as IP4 Tools, wire, and small wires diameter 1mm and greater),
IP. Second digit-5- Protected against low pressure jets of water from all directions
IP. Second digit-6- Protected against heavy seas or powerful water jets (flooding)
IP. Second digit-7- Protected against the effects of temporary immersion in water
IP. Second digit-8- Protected against the effects of continuous immersion in water
I have used these in blue and IP65 waterproof http://www.superbrightleds.com/searc...ccent%20light/
Edit: I didn't use them in the hood. Just giving some information.
Hope this helps.
Greg
Old 12-06-2013, 04:45 PM
rammin2013's Avatar
Rep:37
Thanks for the helpfull info Greg. Time to shop for some lights and see what I can find!
Old 12-14-2013, 01:08 AM
Jerrad Jerrad is offline
Rep:54
Jerrad will become famous soon enough
One of my favorite mods, looks great casey!
Old 12-14-2013, 02:15 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
get your lights from oznium i was first to do this mod and can walk you through any thing you need
Old 01-20-2014, 02:33 PM
WhiteRamSport13 WhiteRamSport13 is offline
Vehicle: 2013 Dodge ram
WhiteRamSport13 is on a distinguished road
Hey Dodgert, do you have a write up on this? I am going to be doing this forsure also a link to exact lights you purchased?
Such an awesome mod.
Thanks fellas
Old 01-22-2014, 10:41 PM
ghorn ghorn is offline
Vehicle: 2012 Ram 4X4 Crew CAb
Trim Level: Custom Tradesman
Rep:74
ghorn will become famous soon enough
Hot glue melts at about 275-F, while underhood temps are commonly 500-F. I'd be curious about a follow-up from the OP to see if it became necessary to re-attach the LEDs after the hot glue melts in summertime.
Underhood lamp with sport hood? abpelch Body & Interior 99 12-17-2014 10:35 AM
Dodge Ram Sport Hood darenspoon 2010 Dodge Ram Forum 16 12-09-2013 06:05 AM
Sport Performance Hood Question Bighert3rd 2011 Dodge Ram Forum 15 03-10-2013 11:03 PM
Replacing hood with aftermarket or sport hood. 2010DodgeRamSport 2010 Dodge Ram Forum 14 02-14-2012 02:28 PM
Sport Hood Chris11Ram 2011 Dodge Ram Forum 24 07-02-2011 06:55 PM
