Old 07-04-2011, 07:08 PM
TORMENTOR TORMENTOR is offline
Vehicle: 2010 Dodge ram 1500 Hemi
Color: Deep Sea Water Blue
Rep:156
TORMENTOR has a spectacular aura aboutTORMENTOR has a spectacular aura about
Default Noise when cruising
I have 2010 ram 1500 crew cab with the hemi and for quite awhile now when I am cruising on the highway doing 60mph or higher, I hear a faint whining noise coming from sounds like the rear end. Anything below 60 mph and it doesn't do it. As soon as I hit 60mph and above the noise starts.
Also the noise is only present when I'm givin it gas to maintain speed. It goes away instantly when I let off the throttle even when still doing above 60. It gets slightly louder if I start going faster.
Anybody know what this could be? Is it normal? The sound resembles A semi truck cruising beside me just not nearly as loud obviously. But that same steady tone
2010 Ram 1500 Hemi Crew Cab 4x4
Bilstein 5100's maxed out, 305/55/20 Cooper Zeon LTZ's, 14" Magnaflow, K&N Drop-in, DiabloSport InTune, HemiFever tuned
Old 07-04-2011, 11:14 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
sounds like gear whine. the dealer might replace the rearend after a test drive if they can confirm that's it.
Old 07-04-2011, 11:50 PM
wickedpissahtruck's Avatar
wickedpissahtruck wickedpissahtruck is offline
Vehicle: 2014 Ram Laramie 4x4
Color: Maximum Steel Metallic 2 tone
Rep:23
wickedpissahtruck is on a distinguished road
I have a similar noise as well. I've got a 2010 Crew Cab Hemi, and it is a bit of an annoyance. I just chalked it up as "normal" drivetrain noise, but I sure would love to know if it is something to be concerned with. Truck doesn't drive any different. Please keep us posted if you do take it in and let us all know what they say.
Old 07-04-2011, 11:58 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
My 11 crew has a similar noise. Will have mine in for service this week and will have to ask the dealer about it. My old Dakota had rearend whine from day one and is still going strong with the whine, the Ram is no where as loud but is in the same mile per hour range. Might just be the Dodge rear ends.
Big Red my old 2011 Sport
Old 07-05-2011, 02:43 AM
Rep:156
If it is just normal drivetrain noise, i can live with it and if that is what the tech tells me, im going to request driving another new one on the lot just to be sure of it. They have been good to me so far so im sure i will get an answer im happy with.
The truck goes in tomorrow at 10 am to have a tech road test it with me, then the next day it gets line-x!
Old 07-05-2011, 04:14 AM
wascobi wascobi is offline
Vehicle: 2010 Ram quad cab
Trim Level: sport
Rep:24
wascobi is on a distinguished road
had mine in last week for the same thing. problem is its not a constant noise. went for a 15 min drive with the tech and nothing. then it happen on the way home..
Old 07-05-2011, 02:44 PM
Rep:156
Ok so just finished the road test with the foreman. We heard it and he confirmed the noise is just gear whine at the higher speeds. He started explaining it all in detail, the word friction and heat came up a couple times. Either way good enough for me, he said it will always be there and it's not hurting anything
ALSO big news for 2011 ram owners. There is a new update for the drivetrain, he said it's brand new and it Effects shifting habits, mds function and some other complaints owners had for driveability
Old 07-05-2011, 02:52 PM
Rep:156
I also went in and got the latest update for my radio and there was a update for the instrument cluster. Apparently the tire pressure monitoring system was inaccurate
Old 07-17-2011, 10:07 PM
CobraZr1's Avatar
CobraZr1 CobraZr1 is offline
Vehicle: 2011 Dodge Ram
CobraZr1 is on a distinguished road
Same problem with Dodge Ram 2011 ,with only 10,000 Km , this noise is not constant but occasionaly on the cruise. ( 60 mph + ). Tormentor explain the exact sound " Semi truck cruising beside me" but a smooth sound . After your explanation this sound is not coming because my lower profile tire. This sound is not constant and the road finish not affect this sound .
Let`s me know.
Sorry for my English
Sylvain
Old 07-18-2011, 01:44 AM
Rep:156
It was determined to be a normal noise from the rear end. Faster you go, more heat, more friction, creates the sound
Ram 2500 with engine noise. Big Ed 2010 Dodge Ram Forum 3 06-23-2012 01:29 AM
Odd Exhaust Noise highlandchef 5.7L (345 cu in) HEMI V8 Specific Topics 10 10-02-2011 11:33 AM
Help With "Whining" Noise From Rear??? GTR0419 5.2L V8 Specific Topics 5 02-07-2011 05:26 AM
Excessive Throttle Body Noise firedog318 5.9L V8 Specific Topics 8 01-23-2011 03:54 PM
2010 Ram 1500 with grinding noise XiNull Dodge Ram General Discussion 4 01-27-2010 11:21 PM
