1997 Dodge Ram 1500 v6 3.9L 2wd - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 07-05-2011, 01:37 PM
yrant88 yrant88 is offline
Vehicle: 1997 Dodge Ram 1500 V6
Trim Level: single cab
Color: faded green
yrant88 is on a distinguished road
Exclamation 1997 Dodge Ram 1500 v6 3.9L 2wd
ok, i just bought this truck and there are a number of small issues that im wondering about. when i start the truck the vehicle idles perfectly fine for a good min. but then it lowers the idle then starts to have some rough idling and some clacking in the engine. now... im sure its not that serious because its not like knocking the engine. it sounds like either a rocker arm assembly or i need new heads. other than that the engine doesnt knock when you give it gas but seems to not have alot of power. its hard to explain its like it will get up and go but like a 4 banger engine... any help or pointers or anything would be greatly appreciated... OH and i did change the sparkplugs yesterday and its running a little bit better than before but still the same issues.
Old 07-05-2011, 09:28 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
First start with giving it a tune up, and clean the THROTTLE BODY most certainly and be sure to clean the IAC. The IAC is what controls the idle, Idle Air Controller lol... The pintle on the IAC gets all sorts of varnish and dirt buildup over time and clogs up then the engine gets horrible idle and other problems. Be sure the replace the air cleaner mount gasket and the throttle body gasket and torque the bolts to 200 inch lbs.
Ok next thing and very easy thing is to put a bottle of fuel injector cleaner in half a tank of gas. This ways you have a really concentrated amount of cleaner to clean the fuel system, injectors, and intake valves.
But I can say for sure once you clean that throttle body and IAC their will be a dramatic increase in power and you will notice it right away and the idle should go back to normal. If the idle doesn't go to normal then it's either a IAC, MAP, or TPS sensor. Generally it's just the IAC most common, be sure when you handle the IAC don't push or pull on the pintle cause it will damage it then you have to buy another one and it becomes expensive after you break stuff.
But do all this and I can almost promise you it will fix everything, just tell me how it goes...
Here are torque specs.
Spark Plugs: 30 FT/LBS
Throttle Body Bolts: 200 IN/LBS
IAC: 60 IN/LBS
TPS: 60 IN/LBS
MAP: 60 IN/LBS
Be sure to give me some rep points, I'm trying to collect some.
Old 07-06-2011, 03:09 PM
Color: faded green
thank you i will check into that. ill let you know when i start on it and how it comes out
2008 Dodge 1500 Trany Question newdodgeowner 5.7L V8 Specific Topics 16 09-26-2016 09:53 AM
1997 Dodge 1500 renne2001 Electrical 1 06-27-2011 12:05 PM
1997 dodge ram 1500 astubborndonkey Newbie Checkin! 14 07-30-2010 01:42 PM
1997 dodge ram 1500 help kainrockzz Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 07-05-2010 10:17 PM
1997 dodge ram 1500 4x4 coil springs rustyolred Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 02-12-2010 09:26 PM
