Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 07-05-2011, 05:49 PM
micali micali is offline
Vehicle: 91 dodge ram
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
micali is on a distinguished road
Default 91 Dodge ram AC and windows won't work
I went out to my truck and tried to roll my windows down but they didn't work. I tried the ac and it didn't work either. What's strange is the last time I drove it everything was working fine.
I checked all the fuses and they are all good. Has anyone else had this issue?
Old 07-06-2011, 10:56 AM
want to drive want to drive is offline
Vehicle: 1990 Dodge ram D150
Trim Level: LE
Color: gray/ blue
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
want to drive is on a distinguished road
is it a power window? Do you hear a sound like it wants to move? Had the same problem on a 1990 ram spay some oil up the door (take off inside door cover and there should be a bing gear that connect to the window "Arms" spay on it) The ac I have no clue.
If you are looking under my truck, you are to close to my truck
Old 07-06-2011, 02:16 PM
It doesn't make any sounds to answer your question. It's power but the ac and the windows are tied together somehow. One day it worked the next it didn't. I will have to check the power at the fuse and see what I get.
Old 07-26-2011, 07:47 PM
i checked the fuse block and there isn't power to either ac or windows. Does anyone have a wiring diagram for this truck?
Old 08-04-2011, 10:53 PM
Does anyone know what this splitter powers? This pic is not mine because the orange one, under the finger, is completely broke on mine. I swapped out the ignition switch and that didn't fix anything.
Old 08-08-2011, 10:50 PM
Well the orange wire controls the blower and power windows. I rewired it to the battery and all is working. Thanks for all the input.
Old 09-09-2012, 12:24 PM
ronniemattix ronniemattix is offline
Vehicle: 1993 dodge ram & 05' ram
ronniemattix is on a distinguished road
im having exact problem and was just wondering if there were any fuses under the hood or other relays that i might not know about. iv checked the fuses under dash.
i wonder am i supposed to start a new thread for this? oh boy
Old 09-09-2012, 01:27 PM
There are fusable links you can check. The pic I posted showed what my problem was. I fixed the broken wire and all is good.
Old 09-09-2012, 02:03 PM
oh my god i cant believe this but thank you, i just typed in a very through explanation of this and went to post it and i was longed out when i longed back on it was all gone i not doing it again but yes all wires going in and out of splitter are hot. the ones coming out are all fuse links that if they just get hot they can become brittle and break inside the insulation with no visible sign. all of the wires coming out the splitter ar about 10" long and hook back into the real wiring harness with a piece of glue filled heat shrink tubing and should be replaced from the batt with the same size wire that they go to after the heat shrink (10ga or 12ga) with a buss fuse or equivalent in them of the right rating (10a 15a) my 93 ram had one orange fusible link broken inside in several places but looked fine. this was the power windows and heater / ac fan not working. this is a little more through explanation. thank you though this site saved me a lot of time diagnosing this i hope this further helps some one else. < this is a link to the photo that i got here. i hope im doing this all right, if not yell at me then. Over.
Last edited by ronniemattix; 09-09-2012 at 02:13 PM. Reason: to add tags hopefully.
ac fan heater fan, power windows
2002 Dodge Ram electrical problems BigD Electrical 11 03-08-2013 04:14 PM
Dodge Ram Van Conversion Window Replacement... ramvan2500 Dodge Ram Vans 4 05-24-2011 11:32 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 10:19 PM
passenger power windows dont work /engine light B1500ram Electrical 12 10-25-2010 10:15 PM
2006 Dodge Ram 2500 Laramie Mega Cab HEAVY DUTY Justin@AACstyle.com Dodge Ram For Sale - Used Dodge Trucks 7 07-21-2010 11:37 PM
