Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram – 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 07-05-2011, 08:08 PM
wcolvett wcolvett is offline
Vehicle: 2001 Dodge Ram 1500
Color: Blue
wcolvett is on a distinguished road
Default Question about towing, 2001 Ram 1500 5.2L
Hello,
I'm new to the truck world, just picked up a 2001 RAM 1500 5.2L Magnum 3 door (is that a club or a quad cab?) short bed automatic. Needs a slight bit of work but runs pretty solid for the most part. Now the question is, I'm looking to pick up a third gen Camaro for something to fix up, and I found a deal on one that's approx. 40 miles from where I live. Tow trucks are too expensive, so I wanted to see about maybe renting a dolly and towing it, but I know ziltch about towing with a pickup truck... I see in the rear bumper where it has the hole(s) for a ball hitch, is it that simple to bolt up a heavy ball hitch to the bumper and towing the car with the dolly? The weight of the Camaro should be around 3100-3200lbs...
Any help/advice would be appreciated...
Thanks,
Warren
Old 07-06-2011, 07:57 AM
MFitzs70's Avatar
MFitzs70 MFitzs70 is offline
Vehicle: 2007 Ram 1500 5.7 Hemi BigHorn
Trim Level: ? Big Horn ?
Color: Reddish
MFitzs70 is on a distinguished road
Here's a quick google search for info on towing.
http://www.uhaul.com/Trailers/HitchGlossary/
I don't recomend the bumper hitch more then likley it will be too high anyhow.
Good luck.
Old 07-07-2011, 09:55 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
With a 4th gen, you could probably do it. They have the crossmember that goes under the bumper and the ball bolts to that. I would not try it on any other generation Ram...too heavy.
About the only thing you can tow on your bumper is a Lawn Mower. The 4th gens have a crossmember that goes from frame rail to frame rail under the bumper and is welded at each end where it meets the frame. Your bumper is simply bolted onto the end of the frame rails.
Mine:
To be honest, I am not even sure how much weight mine can carry on the bumper...but 3200lbs of car on a trailer would be pushing it I think with mine. Let alone an older gen.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 07-07-2011, 09:57 PM
You won't be able to do it with the bumper but a good Class IV receiver hitch you can do it.
Old 07-07-2011, 10:04 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Mine:
That crossmember is actually your hitch I believe your are supposed to be able to bolt something like this to it
Old 07-07-2011, 10:37 PM
ArmyofOne's Avatar
US Army Retired
Rep:1195
you can, but the ball on the bumper actually would go through it, essentially negating the need, except for the height issue.
US ARMY-RETIRED
Old 01-13-2012, 12:21 PM
Stein's Avatar
Stein Stein is offline
Vehicle: 1999 Dodge Ram 1500 4x4
Trim Level: SLT Laramie
Stein is on a distinguished road
I personally wouldn't trust a bumper hitch for anything but moving something around in your driveway. you can buy the whole set up for your truck for around 150-250 depending what class you want and takes about an hour or Uhaul will do it for 300+. if you try it I would go for the dolly they don't weigh that much, a trailer capable of holding a car is probabaly gonna weigh about 2000 lbs by itself. then there is the height issue bumper being to high. now the weight depending on how you position the car on the trailer is going to raise or lower the back of the truck to high or to low that thing is going to sway all over the place putting that much more stress on the bumper. if your only gonna do it 1 time it may be alright but I would say its a gamble thats alot of weight for a bumper hitch. good luck!
Old 01-17-2012, 02:51 PM
nicraage nicraage is offline
Vehicle: 2001 Ram 1500 4x4, 5.2L
Color: Flat Black
nicraage is on a distinguished road
Also, just to note, that uhaul will usually look at your vehicle and tell you if you can or can not use their dolly.
write up on the new 2012 ram 1500 sirrednexx 2012 Dodge Ram Forum 4 05-20-2011 01:45 PM
2001 dodge ram 1500 vs 2008 nissan armada dotthis71 Dodge Ram General Discussion 10 05-07-2011 10:43 AM
Towing question red041500 Towing 16 09-15-2010 10:18 AM
Another Towing Question ram06bighorn Towing 10 07-01-2010 05:03 PM
Maintaince Questions 2001 1500 5.2L 01Dodge1500 Dodge Ram Detailing and General Maintenance Forum 3 05-05-2009 07:24 PM
