Old 07-05-2011, 10:59 PM
grader88 grader88 is offline
Vehicle: 2007 dodge ram 1500
Color: silver
grader88 is on a distinguished road
Default is alignment necessary ?
ok ill admit it, im a welder not a mechanic, my 2.5 leveling kit has arrived at my house, ill be back from camp in a few days and im wondering if after i have installed the kit if it is necessary to have an alignment done on my truck. i already have to go to the tire shop to have the new rubber put on and balanced to i can get it all done in one shot, but if its not something that needs to be done i can spend the money on something else.. like beer.
Old 07-05-2011, 11:59 PM
LeKy411's Avatar
LeKy411 LeKy411 is offline
Vehicle: 2011 Ram 1500
Color: Blue
Rep:100
LeKy411 will become famous soon enoughLeKy411 will become famous soon enough
You should get your alignment done every time you get new tires or wheels put on your truck, so if your messing with the level, the tires, and such you might as well spend the money. The most I've spent around here is $75 bucks to get one done. This will keep your tires from wearing down unevenly, which causes bigger headaches and more money. I've made that mistake in the past and ended up paying way more in tires and a rough ride.
Old 07-06-2011, 01:13 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
Regardless of the tires.....yes by adding the spacers you need an alignment.
Old 07-06-2011, 01:19 AM
volcom54626's Avatar
volcom54626 volcom54626 is offline
Vehicle: 2006 Dodge ram QC
Color: Brilliant Crystal Black
Rep:17
volcom54626 is on a distinguished road
I agree, anytime you mess around with the suspension you should always get an alignment done, or like leky mentioned you will have bigger problems with the tires down the road.
Old 07-06-2011, 05:37 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
The answer is simply yes as others have said. If you are lifting or lowering your vehicle you need an alignment. As always it is advised to check your alignment when you put new tires on as well.
Old 07-06-2011, 04:59 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
While I do recomend getting an alignment I wouldnt say you have to take it right to the shop after you install your spacers.
Old 07-06-2011, 05:46 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Yes is the answer
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 07-06-2011, 08:43 PM
Totally agree ^^^^
alignment question longtravel Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 06-03-2011 07:40 PM
Do I need an alignment now? bones06 Dodge Ram Wheels And Tires 10 04-23-2011 09:04 PM
Question regarding spacers & Alignment Steveo1 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 04-12-2011 07:37 AM
Alignment after level question thatreddodge Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 11-27-2010 04:37 PM
Alignment? bigdaddyII Suspension 13 10-16-2009 07:20 PM
