Old 07-06-2011, 11:09 AM
jgatlin jgatlin is offline
Vehicle: 2011 Dodge Ram
Rep:18
jgatlin is on a distinguished road
Default Switch Placement Problem Solved
I have been trying to find a good place to install a switch for strobes after searching for something that would fit into the right console (where the passenger air bag switch would normally go) with no avail since I have the REC Navigation radio which takes up the extra pocket below the standard radio. I decided to install the switch in the top console. Although it's not stock it looks and works great. See attached photos, hope this helps those of you looking for good switch placement.
Old 07-06-2011, 11:19 AM
Rep:4072
Cool idea! Was it difficult to install?
Old 07-06-2011, 11:25 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
^^^ I am with Cajun was it a pain to run wires up there?
for a using some great ingenuity.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 07-06-2011, 11:31 AM
Rep:18
The install of the switch was pretty easy just drill a hole in the blank and then use a file to perfect the hole to the size of the switch, you have to use cutters and trim a little bit of the plastic fins which are behind the top console. It actually was not bad running the wires. I would say almost easier then tearing the dash out to feed wires to the main console.
Old 07-06-2011, 11:51 AM
Rep:18
Default Console Layout
I wanted to mount switches in the storage compartment on the right, I thought I had found the solution (see switch plate in photo) but then after doing some measuring found it would not work even though it was for a 2008 dodge, so I ended up mounting it up top.
button, console, dash, placement, switch
Transmission Problem 07 Hemi 07Ram 5.7L V8 Specific Topics 14 03-14-2013 07:45 PM
check guages light on DODGEARCHER Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 06-22-2011 11:21 PM
Drivers door lock switch......... bigdaddyII Electrical 9 01-25-2011 12:09 PM
horn separate switch dead short..help! String13 Custom Dodge Ram Interior Modifications - Custom Audio / Video 1 12-31-2010 10:20 AM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 05:54 PM
