Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 07-07-2011, 08:17 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
torque management....In simplest terms, over the years I've tested stalling the motor (1800 - 2200 rpms) before the lights turn green and just nailing the pedal at go and have always been slower when stalling up...
Old 07-07-2011, 08:18 AM
chefred112's Avatar
Rep:656
Originally Posted by ramrt1993 View Post
I was messing around a lil tonight and found that the truck seems to shift smoother and take off better with Tow/Haul on and Trac Control off. I upped the RPMs to about 1,800 I think..(I just listen to when its about to spin, I don't actually check the RPMs) and then I took off and my tires only spun for a split second. Then at the next stop light I was on a 10 MPH roll when I mashed in the medal and then I had a hard time getting traction, I was spinning really bad..it was fun
you confirmed what I just posted..
Old 07-07-2011, 08:21 AM
chefred112's Avatar
Rep:656
more power from the gitgo..
Old 07-07-2011, 10:06 AM
ramrt1993's Avatar
ramrt1993 ramrt1993 is offline
Vehicle: 2011 Ram R/T
Trim Level: R/T
Color: Mineral Gray
Rep:69
ramrt1993 will become famous soon enough
I think I'm starting to understand this...what I've noticed on tow/haul mode is that it makes my RPMs higher by about 700-1,000 RPMs, even during normal driving. So that means that tow/haul mode would be a good thing to have on, right?
What confuses me is why in the world would Dodge put a 2600 stall torque convertor on a truck that starts spinning by 2,000 RPMs when stalling up?
Gatorhyde Spray In Bedliner-MGP Red Brake Caliper Covers-Tinted Windows-Partially Debadged-aFe Stage 2 Intake-180 Thermostat-Groundforce 2" Rear Drop-BT Catch Can-Fastman Throttle Body-ARH Headers 1 3/4"-True Dual 22" Magnapacks-100% Synthetic Amsoil-TYC V6 eFan-Hemifever Tune
Old 09-07-2011, 01:27 PM
MotorCity RT's Avatar
MotorCity RT MotorCity RT is offline
Vehicle: 2010 Dodge Ram R/T
Trim Level: R/T
Color: Inferno Red
MotorCity RT is on a distinguished road
New to the forum......looking for tracks in TX (near Houston) also ready to start mod'n. Thinking:
1. Intake
2. Chip
Dreaming of Headers .....
Old 09-08-2011, 12:01 AM
chefred112's Avatar
Rep:656
some of the serious Ram performance guys are out in Texas...and Houston..lookup Ray (Daytona81)..his truck is seriously fast...
Old 09-08-2011, 10:36 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Chefred, how big is the shot?
As far as launching, DO NOT PUT IT ON THE CONVERTER. Its not like launching a clutch car where coming out of the hole at "max" RPM keeps you from bogging, torque converters are ment to get your truck off the line and they do their job great! Give it enough gas to get it off idle (like maybe 300 rpms) hold it there and dump the brake/mash the gas when you see the third amber light. (assuming were tlaking drag strip)
Idk it putting it in 5 and going for it makes 3rd gear really "2nd prime", but if it doesnt i would shift it myself and just bump it into the next gear every time it shifts. With the pedal on the floor it isnt going to short shift you and letting "3rd gear" bridge the gap between 2nd and "actual" 3rd.
burnouts help, but if you over heat street tires they tend to get a little slimey, youll have to experament with that.
Just because its a 2600 stall doesnt mean you start to move at 2600, dont crucify me for this as ive always had clutch cars and never fully understood autos, but its more of a when the converter is fully engaged. Kinda like slipping the clutch on a car, you move before the pedal is all the way out, but your not putting 100% of the power through the driveline
2011 Big Horn 4x4 -SnowWhite-
Old 09-09-2011, 07:43 PM
chefred112's Avatar
Rep:656
the shot I'm running now is either a 100 or 125 shot...going to the track sunday to play..
Old 09-09-2011, 10:17 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
When do you hit the switch, are you hitting it early or late into the run? I've been watching some of your vids. I remember the little Dakota that was running you sounded like he hit a little too early a couple of times unless the sound was something else. I'm guessing he hit it and turned it back off and then turned it back on but not sure, lol!
drag racing, tow haul mode, traction control
Questions about exhaust (total newbie) titans Exhaust 6 06-22-2011 07:51 AM
Factory Order Questions from a Newbie jhabetler 2011 Dodge Ram Forum 31 05-19-2011 04:14 PM
Newbie questions townsendpn 4.7L PowerTech V8 Specific Topics 2 12-27-2010 03:08 PM
Newbie with questions...and comments. zj4play Newbie Checkin! 11 10-01-2010 12:44 AM
Newbie with questions...and comments. zj4play 2009 Dodge Ram Forum 5 09-29-2010 06:51 PM
