Old 07-04-2011, 02:48 PM
Tenner Tenner is offline
Vehicle: 2006 Dodge Ram QC Hemi
Tenner is on a distinguished road
Default Best Tune for Me?
I just bought a DS Predator. All I have done with it so far is set my tire size and installed the 87octane performance trans tune. I have access all the way up to the 93 octane.
My question is what would be the best tune for my situation. I use my truck as a daily driver both in town and on the freeway. I would like to get the best possible milage. I also will pull a boat, and enclosed snowmachine trailers with it. What would be the best tune for this.
I have a 2006 Dodge 5.7 Hemi. 4x4 My tires are Toyo MT 33x12.50R20. I have a flowmaster exhaust on it and a drop in K&N filter I also have a leveling kit installed.
Yesterday I drove about 300 miles and got 16.6 mpg (according to the overhead gauge. I have not figured it manually yet.) I was driving about 76-77. I was not pulling anything.
Any advice would be apprecitated. Thanks
Josh
Old 07-04-2011, 02:51 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Depends on how much you want to spend on gas really! The 87 perf tune is pretty good!
Old 07-04-2011, 02:53 PM
Josh,
My '07 Ram gets the best mileage on the 91 canned tune. I tried 2 tankfuls of 87 (truck hated it and I hated the truck ), 3 tankfuls of 89 (ran better but not that great...MPG dipped a bit) and since then 92 octane. From the 89 tune I've seen a 4+ mpg improvement on the highway and I don't cruise slowly, normally running around 72 - 74 MPH.
So, for me, the 91 tune worked best but your mileage may vary.
I'd test a bit with different tunes and octanes under similar conditions and do your mileage calculation by hand.
The MPG counter in the truck is a system that measures MPG in real time and will vary depending on speed, load, ambient temp, etc....I've seen mine change with almost every mile when I reset it, drive around town, then hit the freeway. It took almost 60 miles of hwy driving for it to reach the best MPG reading.
Old 07-04-2011, 04:11 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:639
chefred112 is a name known to allchefred112 is a name known to allchefred112 is a name known to allchefred112 is a name known to allchefred112 is a name known to allchefred112 is a name known to all
91 tune as well...
-fast freddie-
one quick 05 hemi qc...with over 250k miles on odo...
performance mods: yes 1/8 - 7.85 @ 93.20, 1/4 - 12.10 @ 113.96
Old 07-04-2011, 04:46 PM
Thanks for the quick responses. After this tank of fuel I am planning on going to the 91 perf. So what is a canned tune? The only options I had under the 87 perf was modify stock trans or performance trans. Is there other options i am missing?
Old 07-04-2011, 05:00 PM
A "canned tune" is what DS includes as standard tunes in their tools, i.e., 87 tune, 89 tune, 91 tune...
So you select the tune you want to use, then modify after you load it.
Old 07-04-2011, 05:36 PM
Ok I see...Its the tunes that are already in the unit when I bought it. Makes sense. Thanks.
What does WOT mean?
Old 07-04-2011, 05:40 PM
916Timmy's Avatar
Rep:1443
Wide open throttle.....foot to the floor
Old 07-04-2011, 05:57 PM
Ok thanks that is what I thought.
Old 07-06-2011, 12:52 AM
andyournameis andyournameis is offline
Vehicle: 06 Ram
Trim Level: trx4
Color: grey
andyournameis is on a distinguished road
Can you run 87 gas with a 91 tune?
Tune Noob kewlguy53403 Diablo Predator Questions & Info! 6 06-16-2011 02:16 PM
diablo approved modification of 91 tune to run 89 octane??? Bighorn5.7 Diablo Predator Questions & Info! 6 05-29-2011 09:05 PM
Predator question... 87 tune on 87 fuel vs 91 tune (modded) to run on 89 fuel limitlessent Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 7 04-23-2011 12:09 AM
DSP 87 Tune vs 93 Tune SilverHemi09 5.7L (345 cu in) HEMI V8 Specific Topics 5 12-26-2010 09:13 PM
Predator - Looking for economy tune Danstona Diablo Predator Questions & Info! 13 06-04-2010 11:23 PM
