Old 07-11-2011, 02:10 PM
ponyboy115 ponyboy115 is offline
Vehicle: 1997 dodge ram
ponyboy115 is on a distinguished road
Question 1997 5.9 overheating?
Hey, I replaced my t-stat(195), my temp sensor, my temp switch, cleaned and flushed my radiator, and replaced my fan clutch. My gauge still reads over 220 fairly quickly after starting, say 5 to 10 minutes. What elso could it be Gauge, do 97s get air bogged? Help Thanks
Old 07-11-2011, 07:28 PM
Reddog170 Reddog170 is offline
Vehicle: 1996 Dodge Ram 1500
Color: Hunter green
Engine: 1993-1993 360ci (5.9L) Magnum V8 230hp 325lb/ft
Rep:21
Reddog170 is on a distinguished road
Sure hope someone figures out this, mine is doing the same thing. Thought about pulling the top end and reworking all of it to help solve this problem and a couple other little things. Shaun
Old 07-11-2011, 08:18 PM
sbsg2005 sbsg2005 is offline
Vehicle: 2001 Dodge Ram 1500 sport 4x4
Color: blue
Rep:23
sbsg2005 is on a distinguished road
You sure the water pump is good?
Old 07-11-2011, 08:44 PM
The Codes's Avatar
The Codes The Codes is offline
Vehicle: 1998 Dodge Ram
Rep:44
The Codes is on a distinguished road
hmm thats interesting, would a cracked head have anything to do with it? maybe another radiator flush? I know the water in mine was super dirty when I changed it after getting it from my dad and it needed to be drained and refilled twice. Wish I could help more man, never had this issue
Old 07-11-2011, 09:43 PM
Default Maybe
The Mehanic that changed my Clutch said he thought the water pump was fine and maybe the gauge was bad. He just wasn't a Dodge guy. I thinking of replacing the t-stat again, but it is a pain in the butt. I sprayed cold water on the radiator today and the temp still read 220 while being sprayed.
Old 07-11-2011, 10:46 PM
deanthecrabman's Avatar
Trim Level: Quad cab
Color: Garnet red
Rep:202
You might want to get one of those infrared heat sensors to see what the temp actually is. Might help you rule out the gauge.
Old 07-11-2011, 11:49 PM
I put a temp probe on many different areas of my engine and radiator. The highest temp I recorded was 169.8 degrees (60 degree night) and that was on the t-stat housing. My temp gauge still read 220 degree. I'm thinking of going to junk yard and grab a gauge and see if that works. thanks for all your advise everybody.
Old 07-15-2011, 09:38 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
They do have to be burped, did you try burping it?
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
overheating when pulling serj5150 4.7L PowerTech V8 Specific Topics 3 05-02-2011 04:54 PM
Heating Problem, and Truck Overheating. Related? hockeyplaya13 Heating & Cooling 2 03-14-2011 03:26 PM
Horrible night... will 2008 1500 wheels fit my 1997? Topdown Dodge Ram Wheels And Tires 20 11-19-2010 04:41 PM
Dodge 1500 Engine swap 1997 318 into a 1998 gourash 5.2L V8 Specific Topics 3 11-19-2009 04:10 PM
1998 trans. stick 5 sp. in 1997 1500 2 WD. WM300 V6 Specific Topics 0 02-26-2009 12:20 AM
