Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 07-07-2011, 02:57 PM
spockmckoy spockmckoy is offline
Vehicle: 2002 2500 ram
Trim Level: LT
Color: almond
Rep:19
spockmckoy is on a distinguished road
Default code po455
any thoughts on places to look in the emissions system for this leak code?
Old 07-07-2011, 04:58 PM
Yes, in this order:
1. Check the fuel cap. Did you just recently add fuel to your truck? A lot of times, this code comes up when the cap isn't fully tight.
2. Your fuel cap doesn't seal to the tank top. You will want to replace the cap.
3. Check your Evap cannister lines. Based on the age of your truck, you might have a faulty, failed or loose vacuum line.
Old 07-07-2011, 05:00 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Michael beat me to the punch, my '06 flipped that code often, usually for a gas cap. I did find the issue more frequently when I hit those super Ox alcohol based fuels.
Old 07-07-2011, 08:24 PM
Trim Level: LT
Color: almond
Rep:19
thanx, I'll check out those items. It originally did it when I bought a lockable gas cap, pitched that and went back to the OEM cap. still comes back after I clear the code. I always at least 3-click the cap after fill up.
Old 07-08-2011, 03:36 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Start at the top of the tank, and follow all the rubber from it, to the canisters, up to the evap solenoid and LDP, and over to the intake. Replace anything that looks remotely cracked or worn. That's the code for a large leak, so it should be pretty obvious when you find it. Not hard to fix, just takes some patience.
Old 07-08-2011, 07:51 AM
Trim Level: LT
Color: almond
Rep:19
Default thanx.
the truck has been beating me up recently. replaced both stacks of rear springs - 1 main broke, replaced all. differential - pinion gears/seal, carrier bearings. The tranny needs $1800 worth of work - rebuild- broken snap ring on OD/reverse. A mysterious problem with the ABS. NO light/code, but pedal will go to floor as I'm almost stopped/ABS kicking in. Going to change the speed sensor in the rear dif I had work done in. the front speed sensors both measure 1200 ohms. IF the rear doesn't fix it,, I may have to go to professionals. I changed brake fluid, brakes, etc. I really want to disable the damn abs. I can stop fine without that technology crap.
need help with p1128 dtc code nitro1965 5.7L V8 Specific Topics 7 09-24-2013 07:01 PM
Threw code on 06 4.7 15 miles from dealership starquestbd22 4.7L PowerTech V8 Specific Topics 9 01-28-2011 10:27 AM
P0753 Code stmabe 5.9L V8 Specific Topics 4 11-18-2010 09:38 AM
Just got a code P0205...please help LSxFBODYgen3 4.7L PowerTech V8 Specific Topics 4 04-30-2010 03:58 PM
03 dodge ram 3500 code p0123 quality03ram Newbie Checkin! 7 01-22-2010 03:51 PM
