Old 07-15-2011, 10:30 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 1998 Dodge Ram 1500 4x4
Trim Level: SLT Laramie quad cab
Color: red
Rep:52
98redbull2 will become famous soon enough
Gutting the cat does NOT rob power, as long as your exhaust is running all the way to the rear of the truck like it was factory. i gutted my cat and put a flowmaster on, better sound better performance, but only gutted it because it was falling apart anyway. i have no 02 sensors hooked up and no cat. the truck does not smell horrible, there is a noticeable difference in the smell of the truck but its not bad. anyway with the gutting the cat its not going to affect your performance if not make it better. It is going to sound like rocks in a tin can but its better than a clogged or bad one.
My truck has 268,000 miles on it and a gutted cat and its been like that for 100,000 miles and hasnt hurted anything.
anyway i found the best way to gut the cat is cut the pipe after the cat and leave some room to put an adapter in and put a couple of clamps on and unbolt the y-pipe with the cat on it and punch it out that way.
Good luck on what you decide to go with.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 07-16-2011, 06:00 PM
Oatess85 Oatess85 is offline
Vehicle: 1999 dodge ram 1500
Trim Level: Slt
Oatess85 is on a distinguished road
if you have not removed the cat yet i would like to inform you that your gas mileage will DROP a ton! i removed mine and i get around 6-9mpg!
Old 07-17-2011, 01:48 PM
98redbull2's Avatar
Color: red
Rep:52
thats not from droppin your cat youve got other major problems
Old 07-17-2011, 06:20 PM
Trim Level: Slt
I've heard from 4 different muffler shops, 2 dodge dealers, and Autozone, napa, advance auto, and they said it would drop gas mileage. I didn't believe them but it drop my mpg
Old 07-18-2011, 11:46 PM
dodgeman9859L dodgeman9859L is offline
Vehicle: 1998 Ram 2500
Trim Level: SLT 4x4 QC
Color: Dark Red
dodgeman9859L is on a distinguished road
well in my case my milage already sucks so that doesnt bother me. i just want the power that y truck should have.
Old 07-20-2011, 10:18 PM
98redbull2's Avatar
Color: red
Rep:52
my truck averages 15 mpg with no cat or 02 sensors
and thats a 98 quad cab shortbed 4wd with a 318 thats alot of weight to toat around for the smaller v8.
thats also the mileage the origional window sticker sais it gets.
donno if that helps but id just gut the damn thing.
Old 07-21-2011, 12:28 AM
Color: Dark Red
plan to. once i can get someone to weld it all back up for me.
Old 07-21-2011, 12:48 AM
450r 450r is offline
Vehicle: 98 ram
Trim Level: sport 4x4
Color: blue
Rep:40
450r is on a distinguished road
Just cut the rear off hollow it out and weld a new 3 inch pipe in place
Old 07-21-2011, 01:01 AM
98 Ram 98 Ram is offline
Color: Metallic Grey Pewter
98 Ram is on a distinguished road
What the easiest and cheapest way to make my truck loud as hell.
Old 07-21-2011, 01:39 AM
notnks's Avatar
notnks notnks is offline
Vehicle: 2009 Ram
notnks is on a distinguished road
Send a message via Skype™ to notnks
Every time that I have done that I took a grinder with cut off wheel and cut 3 sides of a square hole (I usually made them about 3"x3" or 4"x4")and pulled the metal back. Then took a big screwdriver or bar and mushed the insides out. I say mushed because the stuff inside is like a honey come and when you smash it it turns into a powdery dust. It takes a little time to get it all out. I didn't worry about the fine stuff I had glass packs on and the fine stuff just blew right out the tail pipe. Then bend the metal back and weld. I have a wire feed welder that I used which made it really easy. Yes the vehicle ran a lot better, amazing how much better they run with out a plugged cat!! Good luck with it!
Gutting the cat Tonyjr Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 6 01-30-2011 12:47 PM
