Old 07-07-2011, 07:24 PM
devanwon devanwon is offline
Vehicle: 06 ram 2500 mega cab hemi
devanwon is on a distinguished road
Default track/panhard bar questions
okay i have a 06 2500 mega cab hemi... its lifted 12" running 41" tires. i know that the track and panhard bar should be at the same angle or pretty close, my question is i saw a ram in a parking lot with bout the same lift and it had kinda a rotating joint on the track bar i believe, is this something thats available or is it custom??
Old 07-07-2011, 10:10 PM
Those are Heim joints and they are available. I haven't seen a bar equipped with them built specifically for our trucks but I bet they are out there.
Skyjacker, FabTech, Summit, Rockkrawler all advertise these joints and some have suspension kits that feature this type of joint.
I had found a place online a few years ago that had a modified trackbar setup for the 2nd generation rams (they were notoriously weak) but I'll be darned if I can find them again.
Google up heim joint and you'll get a lot of retail seller hits.
Old 07-11-2011, 03:59 PM
ICONRep ICONRep is offline
ICONRep is on a distinguished road
what you are looking for is an adjustable pan rod bar similar to this. not sure if it will work though with your 12" lift unless they did a 12" drop on the bracket?
http://www.iconvehicledynamics.com/store/products.php?product=2003%252dCurrent-Dodge-2500{47}3500-Adjustable-Pan-Rod-Bar
i recently lifted my 04 1ton crew cab cummins with the 4.5" lift dual rate coil, and rear expansion pack and i can tell you hands down, it feels like im riding in a 1ton ford raptor! i do work for ICON, and we are looking to sponsor the site but i am just browsing and seeing the different topics and daily threads...
Few Mod Questions. cmatt4775 2010 Dodge Ram Forum 5 06-29-2011 12:32 AM
Some reg manti. questions GYac 5.7L V8 Specific Topics 12 04-22-2011 01:40 PM
Lowering questions HEMIBLUDA Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 06-20-2010 06:28 PM
Couple questions Quiet Lunatic Electrical 4 09-11-2008 07:45 AM
