Dodge Ram Decals
Old 10-01-2011, 09:31 AM
JRodMTB's Avatar
JRodMTB JRodMTB is offline
Vehicle: 2014 RAM 1500
Trim Level: Outdoorsman
JRodMTB is on a distinguished road
Question Truck Pulling after Bilstein Install
I had my 5100's installed by a reputable shop that a lot of people at work use a couple weeks ago. Unfortunately the shop's alignment rack couldn't accommodate the 20" wheels that we have on our truck so in a pinch I ended up taking the truck to a local Belle Tire to have an alignment done.
This past week I had it back to BT for the 3rd time because the truck is pulling hard to the left. I understand roads have crown but if I straighten out the wheel, the truck will shift lanes in about 5 seconds unless I'm in the very right lane. The last time I was in the shop, dude told me that the truck is as close to factory spec as possible (I have all 3 alignment sheets) and that if I was still having issues that it was most likely due to the lift.
I've rotated tires, made sure that my tires are all the same pressure (35psi) and have done a quick "hand" check on the brakes to make sure wasn't locking up and causing the pull. I'm rolling on 275 Cooper LTZ's and have the shocks set at the 2" lift (2nd ring from top).
Has anyone else experienced this with the Bilstein's or do you guys think my alignment is still off? Thanks!
Old 10-01-2011, 10:58 AM
WyGuy's Avatar
WyGuy WyGuy is offline
Vehicle: 2012 Dodge Ram
WyGuy is on a distinguished road
I've not heard of anyone having that problem with the 5100's. My guess is that the alignment still must be off. Any chance the shocks ended up on different settings?
Old 10-01-2011, 12:03 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Does the problem get worse when the brakes are applied, or stay the same?
brad
Interested in one of my mods?
Old 10-01-2011, 04:02 PM
JRodMTB's Avatar
The problem doesn't get any worse when braking. It is amplified when on the expressway when cruising 70mph.
WyGuy - they're set at the same height. I thought the exact same thing so I checked both the shock position and the height btw the tire and fender.
Old 10-01-2011, 04:18 PM
brad12kx's Avatar
Rep:2581
Can you post the alignment specs?
I'm wondering if they opted to not adjust the caster as much as desired because of it's affect on the camber.....
Also, did they do a 4 wheel alignment check. It is possible that a minor misalignment may have been accentuated by the leveling.
brad
Old 10-05-2011, 08:40 PM
JRodMTB's Avatar
Just and update: I took the truck in to a different shop and had it realigned. The cross caster was set at -1.3 deg (which the specified range is -0.9 - 0.1 deg) so needless to say, it was way off.
They made the adjustments and the truck drives beautifully. It's still pulling a bit when I'm in the very left lane of the expressway, but I'm sure that's due to road crown. I may have them adjust things a bit more to compensate for that - because I tend to drive in the left lane a lot
Old 10-05-2011, 09:40 PM
brad12kx's Avatar
Rep:2581
Yah know.....It really disappoints me when front end alignment people use the 'close enough' attitude. In reality, the front end alignment (full chassis alignment for that matter) is critical to the safe operation of a vehicle, and IMO 'close enough' just doesn't cut it. Either it's absolutely correct, or it is not!
If someone takes the position of a technician doing front end alignments, they need to consider their job as being one of the most important jobs, with one of the greatest affects on safety of any vehicle repair job. If they can't/won't use the attitude that only perfection is 'close enough', then they should consider employment elsewhere.
You reading don't appear to be far off the mark....but it made a huge difference.
-1.3 is NOT....Close Enough.
brad
Old 10-06-2011, 08:55 AM
doug713's Avatar
doug713 doug713 is offline
Vehicle: 2011 Dodge Ram
Rep:33
doug713 is on a distinguished road
I second that Brad. Some people now days have no cares about what they're doing and no pride in their work, it's sad. They are just there to get a paycheck and nothing more. I've gone through similar issues in the past, some people just need to push a broom,,,,lol..
Old 10-06-2011, 09:25 AM
thiggins's Avatar
thiggins thiggins is offline
Vehicle: 2012 Ford F150
Rep:44
thiggins is on a distinguished road
I'd ask for a refund, especially for all of your wasted time.
Old 10-06-2011, 11:34 AM
moparornocar72's Avatar
Rep:630
When I was doing alignments I would drive them before and after as to leave no room for error. The only problems I would ever run into was that trucks were raised or lowered so high a caster/camber kit had to be installed. I would definately ask them for money back. The only other thing that pulls could be caused by if the alignment is in spec is if the tire has a manufacturing problem, it's not common but it does happen and it will cause a radial pull on one or more tires. We had a machine that determined road force by applying almost a dyno on the tire. The local dealers used us to determine the cause of vibrations (esp. ford and their pirellis).
14.268 @ 95 MPH Full Trim
Want to keep your Ram rust free for years? Find out how, in here. ArmyofOne Dodge Ram Detailing and General Maintenance Forum 16 02-13-2014 02:27 AM
Bilstein B6 Heavy Duty Shock Install w/Pics wolfman10 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 15 01-09-2014 09:49 AM
2011 outdoorsman..... No Brakes!!! clintsharley 2011 Dodge Ram Forum 41 03-09-2011 10:45 PM
disappointed with my 2011 ram truck tomhrrs69 2011 Dodge Ram Forum 19 02-24-2011 10:38 AM
truck pulling to the left on highway jerzy1283 2010 Dodge Ram Forum 14 08-01-2010 05:39 PM
