Old 07-08-2011, 12:13 AM
rampage63 rampage63 is offline
Vehicle: 2000 dodge ram 1500 5.2 5speed
Color: purple
rampage63 is on a distinguished road
Exclamation No crank no start ?????????
2000 dodge ram 1500 5.2 five speed
so after smokin my clutch out on the trail ive replaced clutch and rebuilt transfer case, after install, key wont turn over starter, ive replaced fuses and relays and checked all grounds starter tested good, batery is good, but the key will not turn it over all i hear is the relay clicking. i can cross out the relay by going from B+ to 87 and the motor turns, and i found that the crank sensor is broken, so i will replace in the morning, but that shouldnt keep it from turning over. ive checked all my ground connections, all my power connections, and everything is fine, i have a little less than 12.0 v on the control wire to starter and a good B+ connection straight to starter. neutral saftey switch is good, and all connections are clean, im running out of time and patience, it worked fine until the clutch install, now nothing, i dont get it, everything is in good working order, i have good voltage and grounds, am i missing anything ???????????
Old 07-08-2011, 02:28 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
IDK maybe a bad solenoid...
Old 07-08-2011, 02:38 PM
Color: purple
no the solenoid and starter tested fine, but i rigged it for now, i ran a b+ wire to the dash, put in an aircraft toggle switch and then a 60 amp push button starter, and then tapped into the 12 volt line from the relay to the starter, and taadaaa fires right up, i gave up on the problem and i pretty much reinvented the wheel, but when the dodge dealer and various mechanics told me the obvious, which i had already done, i figured it was time to think outside the box (fuse box that is)
lmao
Truck will crank but won't start DougDoug 5.9L V8 Specific Topics 17 07-12-2011 10:57 PM
96 wont crank over or start 96blacky Electrical 3 07-08-2011 08:17 AM
2005 Dodge Ram 3500 Diesel help please wont start.. Hendogg Cummins Diesel Specific Topics 5 03-30-2011 04:23 AM
2003 dodge ram wont start on 1st crank jgraybill 3.7L PowerTech V6 Specific Topics 1 01-09-2011 04:38 PM
2010 doesnt always start after remote start bigdadsram Electrical 1 12-15-2009 09:27 PM
