Old 07-08-2011, 04:55 AM
JRA JRA is offline
Vehicle: 2003 Ram 1500 Hemi CA Express
JRA is on a distinguished road
Default Help Locating the reverse light wire under the dash
I am going to install a backup warning system and need help locating the reverse power wire under the dash to connect to the control box.
Old 07-08-2011, 12:14 PM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
I might be wrong, but I don't believe you'll find a wire that provides power to your backup lights under the dash... you may need to tap into the wire closer to the light itself (at least that's what I did when I installed a backup camera.)
Old 07-09-2011, 12:59 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
There are a couple of places you can find this.
Connector C219
- (Grey 74 pin connector) - Left side of instrument panel - Slot 27 - Violet/Black stripe. It is in a group of 12 wires. Adjacent wires are slot 26 (Pink), slot 28 (Violt/Orange) and 23 (Black/Orange)
Connector C201 - (White 12 pin connector) - Near left instrument panel speaker - Slot 11 - Violet/Black Stripe. It's the only Violet/Black wire in the connector. Slots 5 & 7 should be empty, so only 10 wires in this connector. It is flanked by Slot 10 (Pink/Light Blue) and Slot 12 (Red/Yellow).
Remember, there are more than one Violet/Black wire in your truck, so you have to ensure the one you splice into, is the one you want.
brad
Interested in one of my mods?
Old 06-05-2012, 01:55 AM
Connector C219
I know this is quite old, but when I googled what I am wanting to do, this came up...
I purchased HIDs for the reverse lights. Just for giggles, I want to wire a switch to them so that if I get tail gaters (I get a few) I can hit the switch and on goes the reverse lights that are HIDs
Can I use the same mentioned above?
Or how can't achieve what I am wanting to do?
Do I get power from the battery?
Where can I tap into the reverse light?
Thanks
Old 06-05-2012, 02:07 AM
brad12kx's Avatar
Rep:2581
The wiring above is for the early 3rd generation Rams, so does not apply to your 2012 even remotely. The 2012 wiring diagram is riddled with errors and I am slowly but surely correcting it as I go. As I have not done anything with this circuit I have no way of knowing if the diagram is correct for that circuit so am very hesitant to offer any information on how/what to tap into in fear of giving information that leads to a disaster.
I will recommend discussing this with either a service tech or aftermarket shop that has a very good technician that deals with the electrical systems of the modern vehicles. There is much that can go wrong, and in some cases can lead to very very expensive repairs. IMO, this is not really DIY territory unless you have a very strong understanding of electronics and the new vehicle systems.
brad
Old 06-05-2012, 02:15 AM
Brad, your quick responses always amaze me.
That is what I'll do.
Thanks
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 09:19 PM
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 08:45 AM
How To: "Big 5" Basic Engine Re-Wiring Upgrade - Tutorial Valldar Dodge Ram Knowledge Base 24 05-24-2014 05:39 PM
HID INSTALL SOLUTION for anyone that cares silverbullet13 Custom Dodge Ram Interior and Exterior Lighting 3 08-26-2013 09:54 PM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 03:43 PM
