Transmission Acting Funny - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 07-29-2011, 04:34 PM
HangmansJoke HangmansJoke is offline
Vehicle: 2006 Dodge Ram 1500
Color: Grey
HangmansJoke is on a distinguished road
I have a quick question, sorry to post it here as I have been searching for hours for an answer and can't find jack! (Plus, the garages where I live won't lift a finger for you unless you've paid them - buggers!)
Simply: Will a filter/gasket kit that works with a 46RH work with my 46RE?
I know the RH is hydraulic and the RE is electric, but beyond that, I can find no answers as to any other differences they might have.
Walking away from the computer for a while because if I keep searching for the answer to this question, I'm gonna throw my notebook out the damn window!
Thanks to anyone who can help me with this!
Old 07-29-2011, 08:32 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
The filter is gasket kit for the 46RH will fit the 46RE yes. The 46RE and 46RH are completely the same except for the valve body because the RH as you know is hydraulic and the RE is electronic, other than that everything is the same, the case, the drums, the plates, the discs, the gear ratio, and so on. You can get a filter and gasket kit at the advanced auto parts store for 6.99 comes with 2 gaskets for the two type of mount and a filter, the two different mounts aren't because one is for the RE and another RH because like I said the RE and RH are the same, the extra gasket is for another model transmission. Any questions for anything regarding the 46 series just ask me cause I know that transmission inside and out.
Old 07-29-2011, 08:39 PM
ramvan2500's Avatar
Rep:141
Originally Posted by trab View Post
Hey guys just heard back and they are saying that my valve body needs to be replaced. They wanna charge 780 to do that so i told them to not touch it. So i guess ill replace it myself if it isnt that big of a hassle.
Replacing the valve body is as easy as replacing the filter if you know what you're doing, but you have the manual I gave you which should tell you how to do it, anyways be sure you torque the valve body mount bolts to spec. The reason your valve body is probably bad if the transmission is rebuilt is because of one of two things either they never rebuilt the valve body or they did rebuild it lol, now it sounds weird but rebuilding a valve body isn't easy especially hydraulic valve bodies, their are springs that open at a certain pressure and all you need to do is mix one spring with the other and bam screwed and most transmission shops only rebuild the transmission by replacing the discs and plates and the band and they do nothing else and then they "try" to rebuild the valve body and fail at that. You can go on ebay and pickup a valve body for 250-300 bucks. Typically shifting issues are either because your bands need adjustment, discs are worn or faulty valve body.
Old 08-01-2011, 07:33 PM
trab trab is offline
Vehicle: 2000 Dodge Ram 4x4
trab is on a distinguished road
Hey for the recond it wasnt me u sent the manual to, although i would love to have it. But i replaced my shift solenoid and govener pressure sensor and the truck is now fixed. Go figure it would be some sensors. Thanks again for all the help. o and if sending the manual isnt to much trouble that would really help me out.
Old 08-01-2011, 09:29 PM
ramvan2500's Avatar
Rep:141
PM me your email address and I will be sure to send it to you right away.
Old 08-02-2011, 02:21 PM
I cant send pms yet since im a new member.
trab8989@gmail.com
Exhaust Acting Funny BillyB087 5.7L (345 cu in) HEMI V8 Specific Topics 2 06-26-2011 08:13 PM
Transmission won't shift Hlmeans 5.7L V8 Specific Topics 1 03-27-2011 10:48 AM
45/545 RFE Transmission Overview RamTech Dodge Ram Knowledge Base 13 02-04-2011 04:13 PM
Tranny acting funny Dennyboy 5.2L V8 Specific Topics 2 11-16-2010 11:52 AM
Transmission has slight shift delay??? Quiet Lunatic V6 Specific Topics 5 02-05-2009 06:09 PM
