Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 07-08-2011, 08:30 PM
06Daytona 06Daytona is offline
Vehicle: 2008 Ram 1500 4x4 Big Horn
Rep:25
06Daytona is on a distinguished road
Default Seats won't recline
The seats in my 08 4x4 won't recline. I pulled the tops off today and can't see any visible problem, but I didn't have anything to compare it to at the time. The handle on the side of the seat doesn't seem to move as far as it should on either seat either. I'm thinking I might have to find a wrecked truck down here and take the seat backs, but I'd rather not have to do that.
Old 07-08-2011, 09:19 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Have you tried pushing them forward while lifting on the handles? Have they ever moved since you've owned the truck?
Old 07-08-2011, 09:40 PM
Try moving the seat forward, try the recline latch (you pull it forward) and see if it wasn't bound up a bit.
Old 07-08-2011, 09:56 PM
Rep:25
I've only owned the truck since Monday and they have never moved.
I'll try both suggestions tomorrow and see what happens
Old 07-08-2011, 09:57 PM
Good luck. Let us know how it goes!
Old 07-09-2011, 07:20 AM
Rep:25
I tried moving the seat back forward and moving the handle but nothing happened. My neighbor has the same truck, so I might take a look at his to see how everything works and compare it with mine.
I already told him I that I want to strip his truck if anything happens to it.
Old 07-09-2011, 07:38 AM
justeric1agn justeric1agn is offline
Vehicle: 92 power ram
Trim Level: none
Color: red
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Rep:25
justeric1agn is on a distinguished road
check and make sure there isn't money change stuck in it.
Old 07-09-2011, 08:04 AM
Rep:25
The problem seems to be somewhere in the seat back. When I had them off yesterday the handle on the side of seat moved fine once the bar was disconnected from the back. I grabbed the piece that the bar connects to (it goes from the outboard rotator to the inboard rotator) and tried to move it with vise grips and the movement was limited. There are two tensioner bars that are just above the main bar and I think they might need something to connect them.
When I remove the seat backs again I'll get pics in case someone has a set of seats out of the truck and they can compare the bar placement.
I think the seats were reskinned and the upholstery guy might have done something to the bars
Seats and Carpet Removal Question Krpto1973 2011 Dodge Ram Forum 1 04-09-2011 05:07 AM
2011 Seats SCRT LD RAM - General Discussion 1 02-12-2011 07:28 AM
2010 Aftermaket Heated Seats HKS 2010 Dodge Ram Forum 10 08-14-2010 12:14 AM
SEATS, not staying locked in place lucas318 Body & Interior 12 08-12-2010 10:01 AM
How To Change Seats!!?? Quiet Lunatic Body & Interior 1 04-16-2010 02:39 PM
