squeaking noise rear wheel - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 07-08-2011, 08:50 PM
mrbb1 mrbb1 is offline
Vehicle: 2006 dodge ram 2500
Color: silver
mrbb1 is on a distinguished road
Default squeaking noise rear wheel
Ok I have an 06 2500, gas
4x4
I have a squeaking noise coming from my drives side rear wheel
it is very loud when you first start rolling the truck, get louder as you apply gas to move the truck, but after 20 mph goes away, like a switch is turned off
and its a loty louder in reverse than drive!, and will make the noise just rolling, in Neutral too!
any ideas??
Old 07-08-2011, 09:16 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Look at the rear brake before you start, does the disk have a little rust? In my area the humidity is so high in the summer the disks often rust overnight. On my '06 I had a squeal until the oxidation rubbed off after the first 10-15 minutes of driving.
Old 07-08-2011, 09:42 PM
It may be surface rust on the rotors...that's normal and under light braking you eventually remove it with the pads.
But, in reading your post through again, you didn't say it occurs when you are braking...is it a constant squeal even though you aren't braking? Do you use your emergency brake when parked at home overnight?
Old 07-08-2011, 10:13 PM
Color: silver
I get the noise without the brakes, just it rolling, and it comes back all the time at slow speeds, so surface rust it not the issue
put new pads on about 15,000 miles(hawk performance pads, rotors were like 75%)
I get this noise a lot louder as the truck sits even after just a few minutes being parked
as i drive past 20 mph, the sound just stops, can hear it actually stop
then comes back as you slow, but not as loud as when you first start out
park it, let it sit, and pull out(make it roll) and there its back to loud again!
I can see no visual problems, and its only coming from the drivers side rear wheel
I opulled the wheel off, and all seems good, and i swapped tires(rotated to the front) and still there
no heavy brake dust and rotor and pads are looking good, so??
Old 07-08-2011, 11:06 PM
I'd go a bit deeper then. Make sure your ebrake isn't dragging, that your pads are secure in your caliper and the brake isn't dragging.
Then, moving on past the brakes, check your axle bearing and seals on that side.
Old 07-08-2011, 11:22 PM
Color: silver
I am leaning towards a seal or bearings
its not the bvrakes at all e brake is fine, and working right!
anyone ever change a bearing on a an 06, any know isue's??
Old 07-08-2011, 11:23 PM
I haven't had to change out any wheel bearings on my truck yet but I know I will eventually.
I have not read any repeatable issues with the bearings on our generation truck.
Old 07-08-2011, 11:31 PM
Color: silver
everyone I know tells me I should change both sides
whats your opinion
only one side seems to have issues
but things tend to go close to each other
Old 07-08-2011, 11:33 PM
They both have the same mileage on them. I'd do both of them at the same time.
I do the same thing with bulbs on a vehicle. One tail light bulb goes out, I replace 'em all. That way I don't get to repeat myself later...LOL
Old 07-08-2011, 11:59 PM
Color: silver
I'm kinda teh same way
I like to prevent probelms when i can
guess i will change both side at the same time, easier to remember that way too, when thinbgs were done, so you don't forget which side you did when!
How Is My Truck Equipped? MADDOG Prospective Buyers - Question and Answer Forum 170 05-30-2017 04:17 PM
Wheel Hub Assembly 1998 Ram 2500 write up. Zac2109 Dodge Ram Wheels And Tires 1 06-24-2011 08:29 AM
rear wheel well rust desolit 5.9L V8 Specific Topics 1 06-02-2011 11:07 PM
Bubbling paint around rear wheel well 1BigHemi Body & Interior 18 09-08-2010 08:41 PM
2009 Dodge Ram ST Crewcab 4.7 ?? sernul 2009 Dodge Ram Forum 16 02-19-2010 08:40 PM
