Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 07-09-2011, 09:08 AM
gt8287 gt8287 is offline
gt8287 is on a distinguished road
Exclamation 4.7 dipstick wrong?
i am wondering if my dipstick is wrong on 02,4.7. when i change oil the oil level seems to be way above the full mark. and it always goes more miles before i need to add oil. (220,000 miles on clock). i go about 1500 miles til i need to add half qt. but after that i only get 500 miles to the half mark.
anybody ever heard of this?
Old 07-09-2011, 09:58 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
From what I understand the recommended capacities are not exact, so if it says 5 qts it may be 4.5... When you fill it go by the dipstick. When I do any fluid changes I go about a qt shy of what it says, then top it off using the dipstick.
Sean
snrusnak's Avatar
Rep:1385
Oh, glad to see you have 220k miles on your 4.7, hope mine does as well!
Sean
Old 07-13-2011, 11:07 PM
gts340 gts340 is offline
Vehicle: 2003 Dodge Ram 1500 4x4
gts340 is on a distinguished road
I always fill the recommended amount, run the truck for a minute or so and then re check after the same amount of time. This allows to dipstick to read at operating level. If the dip stick shows low after the truck has been sitting, then I top it off, since most of the oil should be in the pan when the engine is cold.
Old 07-19-2011, 08:16 AM
mclovin7794's Avatar
mclovin7794 mclovin7794 is offline
Vehicle: 2002 Dodge Ram
Color: Grey
mclovin7794 is on a distinguished road
I do the same as well. As gts340 mentioned, it lets the dipstick read at operating level not at a just filled level.
Grab life by the horns.
Old 07-19-2011, 08:20 AM
snrusnak's Avatar
Rep:1385
And yes like they said after you fill and check the level, let it run a minute then recheck, the oil filter alone can hold .5 qt. or more.
Sean
Old 07-24-2011, 12:16 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Before I put my 2" leveling kit on my 02 the dipstick was a spot on when I changed the oil and added the amount of oil listed in the owners manual for an oil and filter change (6 quarts). First oil change after I installed the leveling kit, I put the same amount of oil that I always did and it marked higher on the dipstick then before. I attributed this to the level and for 15,000 miles now just put the same amount I always have.
Sure it'll suck, but it'll make you a man
broken oil dipstick tube SOTASFINEST65 5.2L V8 Specific Topics 8 07-03-2011 08:07 PM
What's wrong with my truck? jbladedx 4.7L PowerTech V8 Specific Topics 3 03-27-2011 11:08 AM
wrong oil in truck ? nitro1965 Dodge Ram General Discussion 5 01-14-2011 11:23 AM
what went wrong? Ram420 Electrical 2 10-26-2010 05:55 PM
Wrong Stabilizer Bar Link recieved from Rockauto. Please help ThomasRam Suspension 5 03-04-2010 10:06 AM
