Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Dodge Ram Decals
Old 07-09-2011, 06:44 PM
am3ftlaud am3ftlaud is offline
Vehicle: 1990 ramcharger 4x4 5.9l
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
am3ftlaud is on a distinguished road
Default still wont start
Not getting any spark, put in new ignition coil, didn't help.
Someone mentioned a gray box on the firewall that goes bad, I located and removed said box it has 4 blade connections on the underside but I (not being a mechanic) can't identify it in my haynes manual. Can't walk into the autoparts store and say give me one of these because they only know how to peck away at the keyboard and get the part you specify.
Old 07-09-2011, 08:47 PM
Hmmm, starter relay possibly
Old 08-01-2011, 01:52 PM
LouisianaMudder's Avatar
LouisianaMudder LouisianaMudder is offline
Vehicle: 1983 Dodge Ram D250 custom
Color: Grey primer
LouisianaMudder is on a distinguished road
I have an 83 D250 and mine is doing the same thing, mechanic friend of ours said we blew out the electrical brain of the truck (that grey box on the firewall) and to get a new one. we're workin on fixing it right now, i'll let you know what we find.
Keep your powder dry
Old 08-04-2011, 03:38 PM
Lonestar17's Avatar
Lonestar17 Lonestar17 is offline
Vehicle: 2014 Ram 3500
Color: True Blue
Lonestar17 is on a distinguished road
Did you get her running?
If not.
Did you replace the hall effect pickup? Do you have voltage on the primary of the coil when you attempt to start it? I believe the smec needs to see a signal that the engine is turning over before it drives the coil either through output 19 on the smec or by energizing the shutdown relay which will allow pos voltage to the coil primary as well as the fuel pump and injectors. The auto shutdown relay will come on when you turn the key to the on (non starting position) briefly running the fuel pump and go off again if you do not turn it over. Once you turn it over it will come on and stay on if the truck runs or while it is turning over. You can hear or feel it's operation while someone turns the ignition on and off and also by listening for the fuel pump.
Were you able to read any codes?
Old 08-09-2011, 10:38 PM
Color: Grey primer
In my case no not yet, though my truck is carburated and has no codes to read that i know of.
Old 08-18-2011, 06:42 PM
Lonestar17's Avatar
Color: True Blue
Sorry thought it was a 1990
Old 08-19-2011, 10:51 PM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Samething happend to mine its not sending a spark from the coil. im freaking lost!
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 08-21-2011, 01:10 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Sounds like the ASD relay. The auto parts aces usually have them listed as the fuel pump shut down relay. It's all tied together. ASD energizes coil. If the PCM doesn't see a signal fromgtge distributor, it de-energizes the ASD, which kills the coil and the fuel pump. So start with the ASD, them move down the line. Hopefully it's not a toasted PCM.
truck won't start, but auto start works. ali15 Electrical 5 07-15-2011 08:44 AM
Darn thing won't start --> clicking noise under dash david05111 5.2L V8 Specific Topics 3 05-01-2011 08:48 PM
Remote start tip snyds 2011 Dodge Ram Forum 3 03-16-2011 09:23 PM
new truck at 50 miles and wont start rich1500 2010 Dodge Ram Forum 11 08-05-2010 09:48 PM
2010 doesnt always start after remote start bigdadsram Electrical 1 12-15-2009 10:27 PM
