Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 07-10-2011, 12:13 AM
Scott B's Avatar
Scott B Scott B is offline
Vehicle: 2002 Dodge Ram 1500 2WD
Trim Level: lowest
Color: Navy Blue
Rep:25
Scott B is on a distinguished road
Cool will stock 2500 or 3500 suspension lift my 1500
Im curious if the stock OEM suspension found under a 2500 or 3500 will lift my 1500 2WD as a cheap lift set up but still OEM quality? Like are they at all the same suspension parts or are they different? i see online i can get a 3 inch suspension lift which is just 1 inch blocks for rear and 3 inch springs for front with new struts/shocks. if its really just springs and rear leafs or blocks will a taller trucks equipment work?
Scott -02 Ram 1500 Quad Cab, Tinted tails top mount brake light, vent visors, body color grill
Old 07-10-2011, 02:08 AM
Most lifts are taller springs for the front and blocks for the rear.
A stock 2500 suspension will work if you can match up all the suspension mounting points and will get you about 1.5 to 1.75"
Old 07-10-2011, 03:38 PM
Scott B's Avatar
Trim Level: lowest
Color: Navy Blue
Rep:25
what do you mean match up the mounting points? aren't the suspension mounting locations the same on all 02 Rams? just taller leafs or springs or coils or srtuts? like if its a heavier duty truck. mu buddy has an 02 2500 Cummin s and it was way taller then my truck stock you know?
07 dodge ram 1500, improving stock suspension. booyah Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 03-14-2011 03:04 AM
1999 dodge ram 1500 4x4 got a 5" Suspension Lift...how much bigger can i go with having to extended jackedupdodgeman Dodge Ram 4x4 - Offroad Discussion 20 03-03-2011 04:50 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 12:50 PM
1500, 2500, 3500 differences. Dieselkiss Dodge Ram General Discussion 16 02-25-2010 12:45 PM
2500 or 3500 MrSame Dodge Ram General Discussion 2 04-29-2009 12:16 PM
