Leveling Kit - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-10-2011, 12:05 AM
02HULKRAM 02HULKRAM is offline
Vehicle: 2002 Dodge Ram
Trim Level: 1500
Color: Green
Rep:20
02HULKRAM is on a distinguished road
Default Leveling Kit
I have an 02' Ram 1500, im looking for a leveling kit, and dont know whats good and whats bad. I need help Is it hard to install leveling kits? where can i find right kit?
Old 07-10-2011, 12:12 AM
Scott B's Avatar
Scott B Scott B is offline
Vehicle: 2002 Dodge Ram 1500 2WD
Trim Level: lowest
Color: Navy Blue
Rep:25
Scott B is on a distinguished road
From the research ive done so far . rough country offers a decent kit and ebay has name brand kits for cheaper. and installation wise i believe as long as you can remove a strut assembly you can do this yourself in under 2 hours with proper tools.
Scott -02 Ram 1500 Quad Cab, Tinted tails top mount brake light, vent visors, body color grill
Old 07-11-2011, 07:02 PM
aviatorcoastie aviatorcoastie is offline
Vehicle: 2004 Dodge Ram Quad Cab
Rep:20
aviatorcoastie is on a distinguished road
I just purchased a leveling kit; all it consists of are new front springs. Easiest and cheapest way to do it from what I have heard.
Old 07-11-2011, 07:06 PM
The Codes's Avatar
The Codes The Codes is offline
Vehicle: 1998 Dodge Ram
Rep:44
The Codes is on a distinguished road
not that difficult to install, however most leveling kits require a spring compressor, and you can go and rent them from autozone or places like that...but I wouldnt put my life in the hands of one of those little contraptions..all that energy springing loose could seriously cause some damage. If you have a industrial grade spring compressor, or a friend with one at his shop or something thats a different story. I dont have access to a good industrial one so I am prob going to have someone install mine for me, that spring popping off the rental scares the crap out of me.
Old 07-11-2011, 07:10 PM
Scott B's Avatar
Trim Level: lowest
Color: Navy Blue
Rep:25
the rough country leveling kit does NOT require spring compressors which is awesome. i have those little spring compressors they are at times unreliable. but ive used them alot and had success. i am not gonna argue with you though. they are unsafe for the most part. which leveling kit did you get and through which vendor?
Old 07-11-2011, 09:52 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
The leveling kit for your truck is a little different then other ram 1500s. 02-05 Rams have torsion bars, your can actually crank your keys up with out buying any spacers or springs.
You can buy the 2" key but it will be about the same result. I wouldnt go much higher then 2" with torsion bars because it'll ride pretty rough
Spring compressors can be really dangerous. If you tighten them evenly there is a much lesser chance of them coming off but I've also had mercedes spring bend the thread all, didnt even bother trying a 2500 spring after that
Old 07-11-2011, 10:16 PM
Trim Level: 1500
Color: Green
Rep:20
Thanks for all your help and comments. I cant wait to get the leveling kit and install it!
Old 07-20-2011, 03:07 PM
pkr11 pkr11 is offline
Vehicle: 2006 Dodge Ram 1500 SLT
pkr11 is on a distinguished road
Ok I'm new to the Ram world, well 4x4 altogether. What exactly is a leveling kit and what does it do? Sorry for the newbie question.
Old 07-30-2011, 09:41 AM
Trim Level: 1500
Color: Green
Rep:20
When the truck comes stock they come at an angle with the frontend lower than the backend. A level kit just makes them even which looks better when you want to get rims and tires etc.
Old 07-30-2011, 11:26 AM
Figured this out with a little more searching on the forum. I think I'm going get a leveling kit just too hold me over until I can afford my 4" lift I want
2009 4x4 Leveling Kit and Tire Suggestions JSBake7 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 07-05-2011 11:31 PM
Any tips/advice for installing a front end leveling kit? RamboObmar 2011 Dodge Ram Forum 16 03-25-2011 04:07 PM
leveling kit shrek Suspension 1 03-25-2011 02:05 AM
2WD Leveling Question bigedschukar Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 20 11-18-2010 09:20 PM
Quoted $1373.50 for alignment after Installing Leveling Kit doozy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 11-01-2010 10:20 PM
