Old 07-12-2011, 02:15 PM
herc herc is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
herc is on a distinguished road
I had the same issue. I never dealt with a salesman at the dealership at all, but worked directly on my purchase with their guy that handles all dealer-installed stuff a purchaser wants to add (tonneaus, buildliners, etc.). He's also the guy that specs all of the trucks they buy for stock.
This dealer never (intentially) orders a truck without the class IV receiver option, but apparently he missed it on mine, because it didn't have one. All of the rest was there, including the framework, wiring and port, etc. So, he put one on, and as far as I know, it is essentially the same piece the factory would use.
My guess is that when it's put on after the fact, the connection method the factory uses wouldn't be possible or would be too difficult, so they use that heavy bolt that comes up through the bumber hole. Mine now has the same ugly high cap over that hole. Other than that, I have the same ratings and capability as if the reciever had come from the factory.
Old 07-12-2011, 02:37 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Everything at the dealership said Class IV, but when I crawled underneath when I got home, the hitch says Class III, and it is a Curt not a Mopar, so I am guessing the dealer had it added because it didn't show up with the hitch. I didn't mind though, since a Class III is rated to 6K and 600 lbs tongue weight, which will accommodate anything and everything I plan to tow.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 07-12-2011, 04:49 PM
Juice420's Avatar
Juice420 Juice420 is offline
Vehicle: 2010 RAM 1500 SLT C.C.
Color: Brilliant Black Pearlcoat
Rep:946
Juice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to behold
Originally Posted by Rescue1 View Post
Juice 420, which hitch do you have?
Thanks for the replys guys, much appreciated. Actually I didn't know that MOPAR made a different hitch. I assumed that because most of the "Hitch" was already there via the tube that's under/behind the bumper, all it needed was the bolt on piece. So your right, I should get the class IV regardless of how much I am towing due to the fact that it simply looks better. Is the Class IV an entire piece that replaces the tube thats already there? Thanks again guys, once I find the right part I'm sure the dealer will make right, plus it helps I know the general manager...
Curt class III. As stated above it works with the flush mount cap.
Justin
Black Mamba- Flowmaster 40 series, Airaid CAI, 20% tint, GTO taillight covers, ATA nerfs, AVS in-channel ventvisors, Curt hitch receiver, Extang Revolution Tonneau, EZ-down tailgate damper, Recon smoked 3rd brake light, Custom painted engine cover
Black Mamba's Thread
Old 07-18-2011, 11:58 PM
Rescue1 Rescue1 is offline
Vehicle: 2011 Dodge Ram
Rep:64
Rescue1 will become famous soon enough
I crawled under a few trucks with the factory hitch installed. Basically everything is the same except two small things. First, the small piece that the bolt threads into is not there due to the receiver being welded to the same bumper/hitch tube that is on my truck. This tube is just like something you would buy, say from curt or Uhaul and bolts directly to the frame. Second, the loops that you put your chains into are slightly different..
So basically, everything is the same, but the factory just welds the piece to the frame connected tube. I can probably remove the whole assembly and take it over to a weld shop and have it done to remove that silly bump cover and bolt...
Old 07-19-2011, 08:40 AM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
You might be able to get a replacement bolt. The one that comes with the Curt hitch has an Allen head with a low profile instead of a standard Hex bolt.
Old 07-19-2011, 03:14 PM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
Another thing you can do is cut the bolt short enough to where the regular cover works, but the bolt is still long enough to be fastened
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 04-15-2013, 11:28 AM
Barney1 Barney1 is offline
Rep:15
Barney1 is on a distinguished road
Mopar's "bolt on" hitch for the ram is a class IV hitch not a class III. Part#: 82213205
It is rated for 12,000-lb tow rating, 1,200-lb tongue weight rating with weight distributing equipment; otherwise 5,000-lb tow rating, 500-lb tongue weight rating
Note the "Fugly" cap in teh picture this is the tell tale sign that the after market hitch is bolted on.
http://www.mopardodge.com/accessorie...m/receiver.htm
Old 04-15-2013, 02:50 PM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2012 Ram CC 1500 4X4
Trim Level: Outdoorsman
Color: Black (PX8)
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
Revived from the dead.
Old 04-17-2013, 10:57 AM
slingshot383's Avatar
slingshot383 slingshot383 is offline
Vehicle: 2011 Ram 3500
Trim Level: Laramie Longhorn
Color: Black/ Gold
slingshot383 is on a distinguished road
If you don't have a hitch or want to put a better one on, go with the Class V Reese or Curt. A lot of 3500 owners are having issues with the factory hitch. Look at the welds in the corners for cracking.
Who supplied OEM trailer hitches to Dodge in 1996? btophek Towing 3 09-02-2011 12:06 AM
front mount hitch for backing into a driveway? austaz Towing 10 01-06-2011 11:18 PM
Lighted Hitch Cover on 09 and up How-to RootBeer Dodge Ram Knowledge Base 7 01-02-2011 10:03 PM
Class IV hitch installation GPSHSLAX Dodge Ram Knowledge Base 6 04-20-2010 09:39 PM
remote start and trailer hitch q's HEMILANCER 2009 Dodge Ram Forum 11 06-28-2009 11:35 PM
