United Radio
Old 07-10-2011, 08:26 PM
stisam80 stisam80 is offline
Vehicle: 2006 2500 hemi
stisam80 is on a distinguished road
Default will diesel spring add lift to a hemi truck?
hey guys I have a 06 2500 4dr 4x4 with a hemi.
I can get a set of disesl springs for the front of my truck.
Will it add any lift to it at all? Im getting a 3in lift was going to try the springs if it gave me a little lift.
Old 07-10-2011, 09:06 PM
Schmitz's Avatar
Schmitz Schmitz is offline
Vehicle: 2005 Dodge Ram 2500 4x4 QC LB
Schmitz is on a distinguished road
I have a 5 inch rough country lift on my Hemi 2500 and I got the diesel coils with my kit and it sat 6.5 inches over stock with out adding tires. So my answer would be yes it will add lift how much may vary mine is a 4 door long bed.
Heres mine
http://i1141.photobucket.com/albums/...4/IMAG0042.jpg
2005 Dodge 2500 4x4 QC LB Hemi, 6 inch lift, 37" Cooper Discoverer STT's, Bully Dog programmer, K&N cold air intake performance throttle body, true duals, debadged.... Soon to come 4.56s and wheels, maybe more lift.
1980 Chevy K20 4x4 9 inches of lift 37" Boggers, 402 BBC, 4 spd, D60, 14ff.
Old 07-11-2011, 05:22 PM
Color: Mineral Gray
Rep:177
diesel springs would make it sit higher, but the have a higher spring rate so it might not ride all that well.
What lift are you looking at?
Old 08-10-2011, 10:26 AM
i got a new 3in lift kit from top gunz. from a local guy. i hope with stock diesel springs up front , 3in lift spacer and 3in blocks in the rear it will seatr leavel or close.
Old 08-10-2011, 02:58 PM
Color: Mineral Gray
Rep:177
Your going to have problems if you only got spacers and blocks. That combo is going to probably give you 5" of lift. Your sway bar links aren't going to last and your track bar will give you all sorts of problems
Old 08-13-2011, 03:31 PM
sorry i also have a drop down track thing from rough country . do i need longer sway bar mounts?
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 10:49 PM
Seeking Help/Suggestions for Commuter Truck dirtystick Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-01-2011 01:27 PM
FIRST TRUCK EVER 05 Ram 1500 qc Hemi RAMBUSA Newbie Checkin! 12 01-23-2011 11:14 PM
spring tech lift 2wd??????? jayrcr Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 07-25-2010 08:34 AM
What would you do? smarthead2006 2009 Dodge Ram Forum 14 01-12-2010 04:18 PM
