Hell Bent Steel leveling kit install, help please asap? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-11-2011, 11:17 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:76
doz will become famous soon enough
Default Hell Bent Steel leveling kit install, help please asap?
So Im trying to get the lower strut mount bolt on but its not lining up at all. It says that the strut assembly must be turned 180*, but I thought that just meant turn it 180* for mounting?
Must I do anything with the strut assembly itself or should it just bolt right up? It seems like its not sitting correctly w/ the spacer installed and I cant get the lower strut bolt in
Any help would be great with this as Ive been fighting it way too long, thanks in advance.
2015 Camaro 2SS/RS/1LE
Old 07-12-2011, 12:03 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I just looked over the directions on their website, it looks like you need to just turn the spacer because of the offset with strut cap then use a jack to get the lower control arm to the height you need to get the lower strut bolt in.
Old 07-12-2011, 01:36 AM
doz doz is offline
Rep:76
Yeah, I got it finally except its not as easy as the instructions say I had a hell of a time with the first one getting the control arm low enough to slide in the strut. Once I did get it in, it didnt fit.
Spacers were exactly the same in my kit so Im not sure about those? What I ended up doing was swapping the struts on either side and they fit like they should without problems.
2004 2wd leveling kit install inof please!! MaRvO75 Suspension 15 04-08-2011 03:42 PM
2011 ? on is to much vibration after leveling kit install 2011 ram 1500 4wd Hemi11 Newbie Checkin! 10 01-12-2011 03:28 PM
Leveling kit install questions jrp0629 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 05-05-2010 10:28 PM
Leveling kit install for '04 2wd rammm Newbie Checkin! 11 12-01-2009 10:06 PM
Leveling Kit Install Phoenix, AZ algunn45 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 12-01-2009 12:53 PM
