Old 07-12-2011, 01:51 AM
2500REDRAM 2500REDRAM is offline
2500REDRAM is on a distinguished road
Default Surging Idle... did the search...
Hey guys/girls, so I spend a lot of time using this site to help trouble shoot issues with my truck and its been a big help, so for that I say thanks! I own a 2001 Ram 2500 5.9l gas. I am having the same issue many experience with these in that I have the surging idle issue, ramps up to 1500rpms. No check engine light. I have searched this issue so not to pull a newb move and post up something that has been covered to death. Just wondering if someone could chime in here that has experience with this issue and post up what is most likely the issue/what most people did to fix the issue. OR post up the most likely causes for this issue. I have seen vaccum leaks, IAC, TPS sensors suggested and throttle body cleaning.
Thanks in advance!
Old 07-12-2011, 11:45 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 1998 Dodge Ram 1500 4x4
Trim Level: SLT Laramie quad cab
Color: red
Rep:52
98redbull2 will become famous soon enough
first easiest most common thing is to pull out that IAC valve or even better pull the throttle body off and then pull the IAC valve out and clean both very well. should do the trick. try that and get back with us.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 07-12-2011, 11:53 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
My first thoughts were either IAC or TPS as well...
Sean
Old 07-12-2011, 11:57 PM
98redbull2's Avatar
Color: red
Rep:52
yup, easiest way is to check voltage on the TPS and clean the IAC out.
Old 07-13-2011, 01:29 AM
The Codes's Avatar
The Codes The Codes is offline
Rep:44
The Codes is on a distinguished road
All of the above are things you should do, also I dont know how accurate the knowledge is but I read somewhere that the surging idle is caused by the computer trying to compensate for the problems that the plenum gasket being blown is causing. So might try checking your tb throat while your cleaning your tb, look for pooled oil or a oil covered tb throat and you most likely need to fix your plenum gasket.
Old 07-13-2011, 03:43 AM
98redbull2's Avatar
Color: red
Rep:52
if it was burning oil that would be a concern, and it would have to be really bad for it to actually affect the way it runs. ive seen reaally bad blown plenum gaskets and the truck ran fine, or by some devine kowincodence his truck might actually be doing that lol ya never know. but i doubt it, not to be a smartass or anything.
does ur truck burn oil snrusnak?
Old 07-13-2011, 10:20 PM
No, no burning oil, other that the surging idle it runs well. Drives me mental. So most find that a simple clean will do the trick? Ill try that first and get back to you guys. Thanks a lot. Oh here is a pick cause well Im a newb.
Old 07-13-2011, 10:30 PM
snrusnak's Avatar
Rep:1385
Pick didn't show up for me..... Yes try cleaning first, if not fixed then check both sensors as described above....then post back.
My 2010 4.7L does not burn oil lol....I think you didn't mean that question for me....?
Sean
Old 07-13-2011, 10:43 PM
The Codes's Avatar
Rep:44
I just suggested to check the plenum because I had this surging idle issue, and of course I was burning oil, and once I fixed the plenum gasket the surgeing idle went away..I get a small surge every once and a while and thats because I need to clean my tb lol but yeah anyways. good luck man
Old 07-14-2011, 11:29 PM
Well I took the tb off the plenum, looked pretty clean in there but the throttle body was a mess. removed the sensors, took some throttle body clean and gave it a good bath, cleaned up the sensors and now it purs like a cougar on saturday night! I don t know if Im imagining things but it seems to have better throttle response and a bit more pull??
Anyways I just wanted to thank all the members who chimed in here. A surging idle fixed with a $5 can of spray and 20min is a great fix in my books. THANKS GUYS!!
Low idle, rough idle problem and more starquestbd22 4.7L PowerTech V8 Specific Topics 9 01-17-2012 04:03 AM
Idle Speed Motor (AIS) problems code 25 jpmassa 5.9L V8 Specific Topics 3 06-05-2011 10:59 AM
Idle Speed Motor (AIS) problems code 25 jpmassa Electrical 2 06-02-2011 11:18 PM
Stalling in cold weather. Air Idle Valve? Todd F 5.9L V8 Specific Topics 3 12-06-2010 10:12 PM
Uneven idle yellow ram 5.9L V8 Specific Topics 2 05-29-2010 06:46 PM
