Old 07-12-2011, 01:01 PM
Carvermitch's Avatar
Carvermitch Carvermitch is offline
Vehicle: 2002 Dodge Ram 1500 quad
Color: Garnet Red metelic
Rep:12
Carvermitch is on a distinguished road
Default Temp gauge moving on 02 5.9 Ram
I just purchased another Ram , 2002 quad 5.9 4x2
When on the open road and most of the time thetemp gauge is around the centre or just under.
On a couple of occassions it climbs to halfway between centre and hot then comes down when on the open road again.
This morning the fuel gauge didnt work and the temp gauge started to climb.
I stopped turned off everything then started again and the fuel guage worked again and the temp gauge came back to normal again.
The engine runs perfect and does not seem to be hot or smell hot.
The outside temp in the air has been very hot and humid but this should not affect it.
It runs perfect and has about 90.000 miles (160 kilometers) on the clock.
Any thoughts please.
Thank you in advance
Paul
Old 07-14-2011, 10:01 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I wish I had an answer for you ~ at least I can give this thread a !
Old 07-18-2011, 12:05 PM
Serrilion's Avatar
Serrilion Serrilion is offline
Vehicle: 2009 Lancer TURBO
Trim Level: ES Sport
Color: Graphite Gray
Serrilion is on a distinguished road
Send a message via AIM to Serrilion Send a message via MSN to Serrilion Send a message via Yahoo to Serrilion
I would say if ya cluster is failing to work, maybe an electrical issue as most factory gauges work off an electrical current unlike other after market ones which require a line to be run to them or there own custom Sensor... I would also bring it to a shop or buy a coolant tester and see what temp it is after its been run. Least it will give you the peace of mind on how cool or hot its running.
Old 07-18-2011, 12:41 PM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
Well a fried with an 05 had his temp gauge rise on him Saturday. It turned out to be his thermostat. It had broken in half! A trip to autozone for a 180 degree thermo fixed his problem for less than 20 bucks. Electrical problems can be difficult to fix. Try the thermo and go from there...
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 07-19-2011, 11:05 PM
Rep:12
Ok thanks I will try your advice. I am sure it is an electrical fault as the fuel guage sometimes wont work as well. If I turn the key off and then start again it will work. I know it has gas in it but the gas light will come on and the gauge falls to empty.
I will get it checked at an auto electrical shop to be sure.
Thanks
Paul
Old 07-20-2011, 11:46 PM
E.L.D. 44's Avatar
Rep:388
No problem. I agree it is most likely an electrical problem somewhere, but I wouldn't want to assume my truck isn't overheating. Good luck with this, I hope it's resolved quickly...
MY MOD THREAD
Old 03-25-2012, 10:29 AM
Rep:12
Further to my earlier problem which I thought was cured, I am now finding that my truck is starting to use prestone and is smelling hot when I stop but the gauge seems ok.
I have out about half a gallon of coolant in over the last few months but there is no sign of leaking anywhere I can find. The oil is fine, clean and she runs perfect, starts perfect and no engine lights on.
I checked the rad after a run and the top hose and rad was hot but the lower hose and area around it were cool.
I also noticed the rad level was down about1 inch in the neck where the cap sits but the level was still ok in the plastic overflow tank. Maybe a cap problem ???
Any suggestions please.
It has now done 177,000 kilometers ( just over 100,000 miles)
Thanks
Paul
Old 03-25-2012, 12:29 PM
Trim Level: sport
Color: green
Rep:643
water pump???????????
Old 09-19-2012, 10:41 AM
Rep:12
I have solved the problem. Replaced the Radiator, water pump, themostat , top and bottom hoses, new rad cap , and flushed and renewed coolant.
Did a thousand kilometer run towing 26 foot trailer and she was perfect. Gauge never went above half way.
No loss of coolant and never smelt hot.
I think I have solved the problem somewhere along the line.
I got all the parts of ebay, most less than third the cost than getting them from Dodge.
Very happy chappy now.
Thanks for all the help and advice.
Regards Paul
Old 09-20-2012, 01:55 PM
Trim Level: sport
Color: green
Rep:643
that should cover any cooling problem!
tranny temp gauge question silvermist Body & Interior 11 06-12-2014 12:03 AM
Temp Gauge Not Working markj Heating & Cooling 1 02-01-2011 09:30 AM
'08 Ram 5.7L Temp Gauge Problem 08RedBigHorn 5.7L V8 Specific Topics 1 12-25-2010 08:42 PM
Temp Gauge Problems? Ramboi92 Dodge Ram General Discussion 5 10-24-2010 03:31 PM
Oil temp gauge install RamZilla Dodge Ram General Discussion 0 06-30-2009 03:07 AM
