Old 07-12-2011, 06:19 PM
c301beatle c301beatle is offline
Vehicle: 97 ram 1500 5.9L V8 4x4
c301beatle is on a distinguished road
Exclamation "Shifting Hard" help me please
i just bought a 97 ram 1500 with a 5.9l V8, it "shifts hard" someone told me to get a vehicle speed sensor and said it would probably fix my problem. is this true? and if so were should i buy the VSS?
Thank you for the help
Old 07-12-2011, 11:07 PM
robustRed's Avatar
robustRed robustRed is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: Lone Star PKG
robustRed is on a distinguished road
A vehicle speed sensor does more than just tell you how fast your going on the speedo. It also relays that speed other components on the truck like, the ABS system if it is equipped with that feature, and the transmission. if the transmission does not receive a good signal, than that could very will be your problem. but before you go and spend money on a new one, check the fluid level via a dipstick if its an automatic, or a fill hole, (if it is a stick shift) on the actual transmission. and as far as buying a new VSS, you should be able to purchase one from your local auto parts store
2WD-Dsp 93 tune-55 series tires-3.92s-PacesetterLT Headers w/ 3in catted y-pipe- DynoMax Race Bullet- 2.2K ohm power wire- hellwig rear sway bar- 190 Degree Thermostat-
Old 07-12-2011, 11:22 PM
robustRed's Avatar
sorry, lol, if its shifting hard its obviously an auto haha!
Old 07-13-2011, 12:23 AM
Jonesey982's Avatar
Jonesey982 Jonesey982 is offline
Vehicle: 2007 Dodge Ram
Jonesey982 is on a distinguished road
Lol, robust at least you caught it before someone else did.
Old 07-13-2011, 12:39 AM
ponyboy115 ponyboy115 is offline
Vehicle: 1997 dodge ram
ponyboy115 is on a distinguished road
Default Tran Temp
I had that problem 5 weeks ago when I got my 1500. My transmission fluid was getting too hot, I was told by my mechanic. He changed my tranny fluid and filter and cleaned my front grill and for air flow. That fixed it, go figure.
Old 02-18-2012, 11:44 PM
Mopartruckin Mopartruckin is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Sport Off-Road
Mopartruckin is on a distinguished road
Is there any chance the previous owner had it rebuilt with a radical shift kit??? Just sayingI had a TH350 built years ago in my racing days that would rattle your teeth when it shifted. I thought it was AWESOME
EDIT: HAHA I guess its a moot point then!!!!
