Old 07-12-2011, 09:58 PM
rocket9244 rocket9244 is offline
Vehicle: 1998 dodge ram 1500 4x4 5.9
Rep:25
rocket9244 is on a distinguished road
Default auto tensioner moving/ rattleing?
is the auto tensioner supposed to move like that?
I notice a rattling noise when I'm driving around 50MPH or above.
I removed a alternator because it was rattling ( making noise) really bad and replaced it yesterday. Question: would a bad tensioner cause a alternator to go bad as in make it rattle?
(I know the serpentine belt is bad)
http://youtu.be/ccOKQfbRdKo
Old 07-12-2011, 11:40 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
wow you need to provide more info you're very vague with your description. I think you're talking about the serpentine belt tensioner? I'm not sure of the symptoms other than a belt coming off the pulleys(has happened to me on other vehicles) but yes the tensioners do wear out in time....I would suggest seeing how tight the belt is, if you can push on the belt and move it more than an inch the tensioner may be bad. Again, not really sure how to diagnose the tensioner, but typically from what I remember when I would push on the belts of my other vehicles they would only move about .5" from the force of my arm.
Sean
Old 07-15-2011, 03:37 PM
carspaz carspaz is offline
Vehicle: 1997
carspaz is on a distinguished road
Default Tensioner
From that video, it sure looks like the entire tensioner assembly is moving. I bet if you pulled the coil off the side of the bracket and tightened that bolt down behind the bracket it would tighten right up. There is a round key on the back of the tensioner that fits into a hole in the bracket. Make sure that is properly lined up and also that it hasn't sheared off.
How to set timing GodSpeed 4.7L PowerTech V8 Specific Topics 5 10-21-2014 01:06 PM
5.7 auto tranny duffman Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 1 02-15-2011 04:03 PM
Stick or Auto Quiet Lunatic Cummins Diesel Specific Topics 7 01-19-2011 01:51 AM
Auto up window feature rolls window down 1/2 chefred112 Body & Interior 3 09-03-2010 11:17 PM
