Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 07-12-2011, 09:54 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Default ArmyofOne's "How-To" Garage: Change a PCV Valve.
The following instructions are for the changing of a PCV Valve on a 2009 4.7L PowerTech V8. However, nearly every car will be similar in technique. Just look for the thing sticking out of the valve cover, with a hose going from it to the intake manifold/TB.
Step 1: Remove this hose:
Step 2: Unscrew clamps right behind the hose shown above (forgot to take a pic) on the main intake tube.
Step 3: Remove Airbox Cover, using clips:
Step 4: Remove Intake crosstube.
Step 5: Unplug this (MAF) sensor----
Step 6: Unbolt 1 10mm bolt right below that sensor. It holds the Intake-box-thing in place . Yes thats the technical term.
This is what you should see:
On the drivers side/rear of the valve cover is the goal...the PCV Valve.
Step 7: Unclip PCV Valve, twist out and pull:
Step 8: Clean PCV Valve (I did as a temporary solution, due to work I cant get to autozone or the dealer till saturday), or Install a new one, and reassemble.
Hope this helps someone!
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 07-12-2011, 10:18 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Nice write up!
Old 07-12-2011, 10:24 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Thanks! this helps me lol! It looks like you and I have the highest mileage of the later year trucks, I should maybe change mine soon too for peace of mine and a few bucks.
Sean
Old 07-12-2011, 10:43 PM
ArmyofOne's Avatar
US Army Retired
Rep:1195
Of course you should! Its cheap insurance. I have never paid more than $10 for a PCV Valve, and it keeps your engine from leaking.
If you just want to clean it, just spray it with Carb/choke cleaner.
US ARMY-RETIRED
Old 12-30-2012, 10:00 PM
forester01 forester01 is offline
Trim Level: Quad Cab SLT
forester01 is on a distinguished road
Thanks, I've got the PCV valve ordered and should be installing it next weekend. Any tips for replacing all 16 plugs and wires, 95K maintenance.
Charley
Old 12-30-2012, 10:28 PM
snrusnak's Avatar
Rep:1385
Charley
Where'd you order the pcv valve from?
Have you changed your intake side plugs yet? They are supposed to be replaced at ~50k miles. They are a Bosch plug, SPFR8TE2AA. The exhaust side plug is good for `~100k miles. It is also a Bosch plug, SPFR8TI332. Wires shouldn't need replaced. The intake side plugs sit directly under the coil, the exhaust side has a small wire from the same coil(I'm not even sure if the wire is replaceable separately or if the whole coil needs replaced). Supposedly you need a thin wall spark plug socket for the intake side plugs, as a regular socket is too thick to fit. Also supposedly the boots on the coils tear/break easy, so be careful.
Sean
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 10:17 PM
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 03:59 PM
Oil Change and Quick Change Valve wallym777 Oil Change 16 03-06-2011 05:55 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 01:00 AM
