Old 07-13-2011, 04:16 PM
raydulce raydulce is offline
Trim Level: Big Horn or Sport
raydulce is on a distinguished road
Default Front Suspension Hop
I've driven several friend's and also test drove a few new 2009-2011 RAM 1500s, and noticed the front end feels a little jumpy to me. (all big horn or laramie - crew cab 4x4s, 5.7 Hemi). Even under mild cornering the front tires don't feel very well 'planted' on a bumpy corner. Is this a common issue? Anyone had trouble with it? Is there an easy fix? I really want to buy a new RAM, but even my 10 year old truck's old front suspension inspires more 'confidence' that i'm not going to understeer the corner.
Thanks!
Old 07-17-2011, 03:05 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 07-25-2011, 06:53 PM
Koshka73 Koshka73 is offline
Vehicle: 2008 Dodge Ram 1500 Quad 4WD
Koshka73 is on a distinguished road
I've got a 2008 Ram with about 60K miles and it does the same thing. I thought it was the front and rear struts/shocks that were bad, but maybe not. I am planning on putting in a Ground Force suspension to lower and level the truck without sacrificing the 4WD capability. We'll see how that works. Of course I'll be changing out the shocks and struts at the same time so it may be difficult to determine what exactly the fix is if it works.
Old 07-27-2011, 12:11 PM
SDoriginal SDoriginal is offline
Vehicle: 2005 Ram
SDoriginal is on a distinguished road
I have a 3rd gen Ram and have the same problem! I've taken my truck to a suspension shop and they told me it's real common with the 1500 Rams. Bump steer can be caused by a lot of different things, but I haven't been able to fix it. I've been told you can replace the factory bumpstops with some more progressive cone shaped aftermarket ones, but that takes some considerable work. Maybe some nice heavy duty shocks? Maybe a custom steering dampener like the 2500 and 3500 have? bottom line is that it is a common problem on our trucks and there is no easy fix...
If it ain't a hassle, it ain't low enough...
2006 vibration 55mph rake1 Suspension 41 03-07-2014 08:52 PM
Snowplowing with my 1500 johnf15 2010 Dodge Ram Forum 7 11-29-2012 04:32 PM
Squeaking front suspension, turning and bumps Lockard191 Suspension 3 03-25-2011 08:04 PM
2007 Big Horn front suspension dee Suspension 1 06-03-2010 06:13 PM
Front Suspension TerryXn9 Dodge Ram General Discussion 3 02-09-2010 02:36 AM
