Old 07-14-2011, 09:29 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I'm no expert on what mufflers sound like what, but I'd personally think glasspacks would be loudest (that's what you had right?). A straight through magnaflow would be loud as well. I would compare costs of doing y pipe with single in single out with dual to double in single out, and go with what's cheaper, it should be the same basically performance wise.
Sean
Old 07-15-2011, 10:14 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
freddie: is that a chambered muffler or straight through type? Your setup is really different from what is normally seen. Does having an h pipe really benefit at all even though you have scavenging from the dual in/single out? It sure looks like you have cats, are they hollow?
mag is straight through..I wanted to sound low tone and muscular..it just makes the cutouts sound soo much louder. The H pipe helps tq performance down low. I wanted to try and get the best of both worlds by doing a 'hybrid' type of true duals but not lose low end performance that true duals show. plus..all my piping is 3" and the single out is 3.5"... yes, the cats are dualed with 3" straight pipe run through them (for inspection)
-fast freddie- one quick 05 hemi qc...with over 275k miles on odo... on the 5.7, stoker 6.4 now...Inertia Motorsports 392 stroker
Old 07-15-2011, 10:18 AM
chefred112's Avatar
Rep:656
yup..here is the H..
Old 07-15-2011, 12:08 PM
snrusnak's Avatar
Rep:1385
Thanks for the pics. I had planned on doing my setup with shorties, stock cats, Y pipe to single in single out magnaflow. I still don't know if I believe having an H or X pipe before a Y pipe(basically what your muffler is) is beneficial (I think I'd need to see dyno to believe it), but not that I'm saying your wrong, I've just never seen this before...
Sean
Old 07-15-2011, 01:33 PM
BooBear185's Avatar
BooBear185 BooBear185 is offline
Vehicle: 2004 Dodge Ram 1500
BooBear185 is on a distinguished road
I just called to see how much it would be to put headers, new cats, dual super flow 44mufflers and straights out the back........ and I got told that the headers will not be passable under state emission laws or inspection. So before you do any changing to your exhaust system I would advise you to check with local and state laws on inspection...... unless you want to switch your exhaust out every time you have to go for inspection.
Old 07-15-2011, 01:39 PM
Calebbrown Calebbrown is offline
Vehicle: 2004 dodge ram 5.7
Color: Patriot blue
Calebbrown is on a distinguished road
We don't have any inspections here in Oklahoma? Do you honestly have to take you truck to be imspected everyso often that seems like such a hassle
If you can't RAM it,
F**K it!!!
Old 07-15-2011, 05:28 PM
chefred112's Avatar
Rep:656
it is a hassle...that's why i have 2 set's of exhaust.. to make mine smog legal for testing I switch my longtubes for shortys (that are certified in my state) with stock cats and then add a tip to the dump so it exits out the side for their tester..
Old 07-15-2011, 06:48 PM
Color: Patriot blue
Dang that sucks well since I don't have inspections! Should I do longtube headers with my stock cats with 2 to 1 single in single out? Does that sound about right cause I have true duals an I feel like I lost power with them due to back pressure I guess? So would the setup I stated before be better?
F**K it!!!
Old 07-15-2011, 08:20 PM
chefred112's Avatar
Rep:656
that's exactly why I went single out...you need a little back pressure for efficient scavenging..
Old 07-16-2011, 01:48 AM
Color: Patriot blue
Can some one explain the main differences in longtube an shorty headers?
F**K it!!!
Exhaust Questions, concerns, and general stuff that has been stated time and time ShotGunWillie Exhaust 12 12-08-2011 12:07 AM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 06:00 PM
popping through exhaust??? need help Travis 5.2L V8 Specific Topics 4 04-29-2010 08:19 AM
What would you do? smarthead2006 2009 Dodge Ram Forum 14 01-12-2010 03:18 PM
Exhaust on my Truck JBSPartans05 Exhaust 9 01-05-2010 09:50 PM
