Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 07-13-2011, 06:50 PM
EWC88 EWC88 is offline
Vehicle: 2002 Dodge Ram 1500
Rep:25
EWC88 is on a distinguished road
Default Another person with a/c problem
Well my a/c just started acting funky yesterday. I had the a/c on the second level of speed, out of no where the a/c fully shut off. It won't work at any speed besides max, if you lower it it'll turn off fully. Also at that high speed it makes a noise. What can be the issues with this stuff?
Old 07-14-2011, 08:14 PM
chris0001's Avatar
chris0001 chris0001 is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: SLT QuadCab 4x4
Color: SILVER
chris0001 is on a distinguished road
I actually had this happen to me a couple of weeks ago. Pardon the not tech. terms.... Under the glove box you will see a connector attached to the blower assembly, (a/c and heater module). Check to see if the wire harness is properly connected, (mine was out on one side). If that doesn't work for you the resister module is 50 or 60 dollars up here and its easy to replace. Again I'm sorry if the actual names aren't correct but my head is on vacation,(we leave at 5 am tomorrow morning and I'm having a packing break).
Cheers!
[/SIGPIC]
Old 07-21-2011, 01:06 PM
Rep:25
I looked under glove box saw a connector with a green wire out, don't know if I connected it right, I'll take a pic and show.
The air problem is even doing it without ac on, it does it with heat and normal air. Could it be same problem?
Old 08-04-2011, 03:45 PM
cabnfevr's Avatar
cabnfevr cabnfevr is offline
Vehicle: 02' RAM 1500 SPORT
Color: blk
cabnfevr is on a distinguished road
sounds like a blower motor resistor. Usual symtems are blower only works on high. I have done a few on some cars none an a ram. Usually not real hard to replace about $60.00 pending on vehicle. You shoul be able to youtube it.
Old 10-28-2011, 08:27 PM
Rep:25
Well I finally got to fix this problem BUT ran into a issue I think. When I took old resistor out alot of crap (leaves and all) fell out from the hole. I look up inside it and saw there was alot of the crap on the grate (don't know what to exactly call it) Is this bad? I put the new on still in and it still makes a loud noise when it runs, and I guess it works, low is pretty darn low were I can't feel it, is that normal?
Transmission Problem 07 Hemi 07Ram 5.7L V8 Specific Topics 14 03-14-2013 07:45 PM
Dealerships: A User’s Guide RootBeer Dodge Ram Knowledge Base 3 05-04-2012 06:03 PM
First Dodge - First Ram - First Post - First Problem koolaidzx2 Newbie Checkin! 11 01-17-2011 01:10 AM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 05:54 PM
Yet another HID problem griffin407c Custom Dodge Ram Interior and Exterior Lighting 10 10-27-2009 05:37 PM
