Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 07-13-2011, 08:11 PM
The Codes's Avatar
The Codes The Codes is offline
Vehicle: 1998 Dodge Ram
Rep:44
The Codes is on a distinguished road
Default DTC P0140...help
So my truck is throwing a P0140 code...as far as I can tell that is something to do with my rear o2 sensor...can anyone help me with this?
Old 07-13-2011, 09:48 PM
Raneman's Avatar
Raneman Raneman is offline
Vehicle: 2004 Dodge Ram
Rep:22
Raneman is on a distinguished road
1/2 O2S Stays At Center. Just copy and paste that and search it. Youd probably get the most results that way.
Mopar or no car
Old 07-13-2011, 10:08 PM
The Codes's Avatar
Rep:44
search on google? bank 1 sensor 2 no activity-thats what the internet says the problem is..I have no idea how to fix that however..
Old 07-14-2011, 06:00 PM
Raneman's Avatar
Rep:22
This link might help.
http://www.obd-codes.com/p0140
Mopar or no car
Old 07-14-2011, 06:32 PM
An O2 sensor has quit working, the connection may be loose or the wiring has shorted. You have 4 in the system.
Old 07-14-2011, 07:42 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:2477
Smile
There are two O2 sensors for each manifold one upstream of the catalytic convertor and one downstream. They do wear out. I'd Just replace the O2 sensor and be done with it. Bank 1 is usually on the left side and sensor 2 is usually the downstream one. If you have one bad the other downstream one should also be changed because it won't be long before it fails as well. I had this same problem on an 03 Intrepid. Replaced both downstream sensors and that fixed her up. There is a chance that you could have a loose connector or another electrical problem however if you have high milage it is more than likely the sensor itself. Good luck and keep us posted.
sales@revelperformance.com
