Old 07-13-2011, 11:10 PM
deervalley deervalley is offline
Vehicle: 2008 Dodge Ram
Color: Grey
deervalley is on a distinguished road
Default 2008 2wd 1500 procomp 6" knuckle/crossnember lift question
I recently purchased this 6" lift for a song, but I'm not ready for a 6" lift yet. Does anyone know if I can use just the spindles from the lift and get 3"s
Thanks, Larry
Old 07-14-2011, 02:21 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
I know the CST spindles can be purchased seperately from their 7" kit so I would think that yours would be the same?
Might have to give Pro Comp a phone call just to make sure.
Old 07-14-2011, 10:57 AM
Color: Grey
Thanks Rammin,
Do you know if the spindles will work with 17" factory rims? On the Pro Comp site it says 18-20" for the rims, but I am not sure why that would be.
Old 07-14-2011, 11:27 AM
Rammin's Avatar
Rep:44
Yeah that doesn't make sense either. The CST kits will work with 17's so I would think the Pro Comps would too but if the site says only bigger then ???
Old 07-14-2011, 11:56 AM
volcom54626's Avatar
volcom54626 volcom54626 is offline
Vehicle: 2006 Dodge ram QC
Color: Brilliant Crystal Black
Rep:17
volcom54626 is on a distinguished road
The pro comp lift is a crossmeber lift where as the cst is spindle and coil that's why you can use only the spindles on the cst and gain 4" lift, the pro comp however won't allow you to do this because there spindles ad no loft they are just 6" longer to accomadete the 6" coil that can be used by lowering the crossmember
Old 07-14-2011, 11:59 AM
Rep:17
As for the rim issue I would think its just a matter of the right backspacing and stock wont work
Old 01-08-2012, 01:45 AM
keala's Avatar
keala keala is offline
keala is on a distinguished road
I'll buy your lift if u haven't used it.
2009 dodge ram laramie 2wd
Old 01-10-2012, 11:58 PM
wbowyer wbowyer is offline
Vehicle: 2011 Dodge Ram 1500
Color: Inferno Red
Rep:71
wbowyer will become famous soon enough
Have to check the backspacing on the stockers, you'll probably need spacers for them not to rub. Can only have a max of 5" of BS (and I believe thats with an 18" wheel).
Which lift kit for 2011 Ram 1500 Sport? sinistersix Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 16 06-04-2011 01:11 AM
6" Lift Kit for '08 Ram 1500 that bolts on JRF3282 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 05-08-2011 01:33 PM
Factory installed LIFT KIT?? 1999 1500 4X4 ARMedNBangin Dodge Ram 4x4 - Offroad Discussion 8 03-25-2011 08:29 PM
2011 Ram Crew Cab 1500 4 x 4 Lift Question Hellspawn1 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 03-18-2011 08:58 PM
3 inch body lift question 95ram Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 10-04-2010 10:26 PM
