Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Tuning Discussion > Diablo Predator Questions & Info!
MOPAR DECALS
Old 07-13-2011, 10:11 PM
Raneman's Avatar
Raneman Raneman is offline
Vehicle: 2004 Dodge Ram
Rep:22
Raneman is on a distinguished road
Question Knock? Not sure what to think about this.
This is at idle. Is that bad? Im not sure whats what.
Mopar or no car
Old 07-15-2011, 09:44 PM
robustRed's Avatar
robustRed robustRed is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: Lone Star PKG
robustRed is on a distinguished road
Its probably just bad gas. what octane and performance tune are you running?
2WD-Dsp 93 tune-55 series tires-3.92s-PacesetterLT Headers w/ 3in catted y-pipe- DynoMax Race Bullet- 2.2K ohm power wire- hellwig rear sway bar- 190 Degree Thermostat-
Old 07-16-2011, 01:02 PM
Raneman's Avatar
Rep:22
But every time ive checked thats what it was showing. And 91 tune with 91 octane.
Mopar or no car
Old 07-17-2011, 01:12 AM
robustRed's Avatar
by looking at that live data, its hard for me to say if that is normal voltage to the sensors or not, but by looking at that timing retard, i would say probably not. that is if that is 15 degrees of timing being pulled. but try adding some octane boost and see if that helps/fixes the problem. if not, try loading the stock tune back on and look at that data and compare.
Old 07-17-2011, 01:53 AM
Raneman's Avatar
Rep:22
Well you lost me a bit...but is there a way i can tell if that is normal voltage going to the sensors? And ok ill try that stuff. Thanks for the help! Rep
Mopar or no car
Old 07-17-2011, 11:25 AM
robustRed's Avatar
with my combine knowledge of knock sensors and google's help, this is what i compiled.
: A knock sensor basically acts like a stethoscope; it picks up a specific frequency that is produced when there is a knock or ping. So what is happening is, there are a bunch of things happening all at once and it confuses the knock sensor so it starts producing a little voltage(sensor hears noise-produces voltage). The normal operating voltage is usually low(5 volts max) so a little voltage like you are seeing should be normal.
but to be on the safe side, if what i suggested doesn't help, listen for a knock or ping in the driveway. if there is none, then this is normal.
Octane Rating (good info) Jay Fuel System 21 06-08-2011 01:02 AM
Regular gas in a 2010 ram with a hemi? Ray Dodge Ram MPG Zone 31 01-21-2010 12:04 AM
What kind of gas do you use?????? bransonshemi Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 61 12-08-2009 10:38 PM
Octane Rating (good info) Jay LD RAM - General Discussion 3 03-27-2009 08:30 AM
Cold Engine knock 95 ram 5.2 liter kccoln 5.2L V8 Specific Topics 3 02-17-2009 06:03 PM
