Old 07-14-2011, 08:15 PM
sethprofitt sethprofitt is offline
Vehicle: 1998 Dodge Ram 1500
sethprofitt is on a distinguished road
Default 98 ram 1500 rearend problems
I recently stripped my spyder gears out in my rearend while doing "tug a truck". I welded the spyder gears together but the welds broke after about a week. So i bought a spool to replace it but i'm having alot of trouble removing the old gears. I removed the bolt that goes into the center pin and beat the pin with a hammer and it wont budge. I'd appreciate all the help i can get.
Old 07-14-2011, 09:13 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Try beating it out from the other end if you still can't get it out then de-grease everything very well and heat up the metal around the pin this will cause it to expand a little then hit the pin with a hammer. Try heating the metal for about 15 minutes, be sure to spread the heat so don't focus the torch on one area.
rear axle, rearend, spyder gears
Erratic Idle and dying problems on 97' 1500 5.9L chrismcr6 5.9L V8 Specific Topics 8 01-26-2012 10:32 PM
Multiple electrical and Mechanical problems Log - 1998 Ram 1500 gwtaz Electrical 7 03-01-2011 01:19 PM
Pending ram 1500 purchase need some info! letsjet Dodge Ram General Discussion 2 01-18-2011 03:52 PM
2007 1500 2WD 1500 Sport/want Bilsteins and coil spacers/rear blocks DanoHB Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 03-21-2010 11:59 PM
