MOPAR DECALS
Old 07-15-2011, 02:24 PM
moose3 moose3 is offline
Vehicle: 2011 Ram
Trim Level: Sport Crew w/Rambox
Color: Deep Cherry Red
Rep:36
moose3 is on a distinguished road
Default Truck stuck in Manual Shift Mode - Anyone Else?
I started my truck after work yesterday, and put it into drive, it acted funny, like it was in neutral or that the trans was slipping, had to rev up before it started to move. Looked down and it was in 4th. I tried to shift it up or down, nothing. Put it in neutral and back, still 4th. Put is into park and then drive again, still 4th and it lurched when it was engaged into drive. Ended up turning truck off, on restart all was fine. I never use the sport shift mode. I have had the flash for the transmission, done a month ago. First and Only time this has happen.
Not worth involving a dealer, unless it can be repeated, or at least happens more than once.
Anyone else?
Old 07-15-2011, 02:50 PM
16again's Avatar
16again 16again is offline
Trim Level: SLT Big Horn Edition
Rep:58
16again will become famous soon enough
Been having it here for months. Had the update done and still the same thing. Just shut it off and re-start it. Clears it right out. Apparently whatever it is leaves no trail so when they scan it, nothing shows.
Old 07-15-2011, 05:13 PM
Vehicle: 2011 Ram
Rep:36
Well I am not sure if it is comforting or not that someone else shares in my issue. Hopefully chrysler will get it figured out.
Old 07-15-2011, 08:20 PM
Kop8456 Kop8456 is offline
Vehicle: 11 Dodge Ram Laramie longhorn
Trim Level: Lariame longhorn
Color: Brown/Gold
Rep:20
Kop8456 is on a distinguished road
Wierd for sure...happens again break out your phone and shoot a video of it while its happening. I think that would be more than enough to prove it.
Old 07-15-2011, 10:55 PM
drp6982's Avatar
drp6982 drp6982 is offline
Vehicle: 2011 3500 SLT Diesel Dually
Trim Level: 3500 SLT
Rep:185
drp6982 has a spectacular aura aboutdrp6982 has a spectacular aura about
Hmm... I have not experienced this but glad you brought it up incase it does happen to me. I probably wouldnt make an issue out of it unless it starts happening more frequently
My Mopar Stable: 07 SRT8 Charger 440 Stroker with Direct Port Nitrous (1320ft - 9.18 @ 147mph)'
2014 Dodge Durango R/T Hemi
2012 Chrylser SRT8 300 Fully built 392 on 10Lbs of Boost
2011 Ram 3500 SLT Big Horn Dually
Old 07-15-2011, 11:57 PM
philpott50 philpott50 is offline
Vehicle: 2011 Dodge Ram
Color: Rugged Brown Pearl
Rep:49
philpott50 is on a distinguished road
If it happens again I would leave it just as is and trie to get it to a dealer without shutting it off. The will be able to scan it then and find the problem. By doing this it does not clear the code. Good luck with the problem.
Old 07-16-2011, 01:16 PM
16again's Avatar
Rep:58
Cant really drive it when my does it. I tried moving a short distance ONCE. When it changes gears it will give you whiplash. Seems that whenever it happens the line pressure in the trans must increase. Almost as if you have a hard hitting shift kit installed. It also takes more throttle to get the truck to even move.
Old 07-16-2011, 05:47 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
See other thread in '10 Ram; TRUCK STARTS IN 4th GEAR.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 07-17-2011, 06:39 PM
16again's Avatar
Rep:58
Thanks, I replied there as well.
Old 07-18-2011, 07:53 AM
tomhrrs69 tomhrrs69 is offline
Trim Level: Quad cab, Big Horn
tomhrrs69 is on a distinguished road
My truck does the same thing also. I'm hoping that the dealer will be able to catch it. So far they haven't been able to figure anything out yet.
How long have you been waiting? Bert66 2011 Dodge Ram Forum 62 06-07-2011 04:46 PM
2010 Owners manual with 2011 Truck nikeman 2011 Dodge Ram Forum 5 05-15-2011 11:13 PM
My truck has trouble starting... no one can figure out problem Pork Chop 3.7L PowerTech V6 Specific Topics 15 05-14-2011 09:14 PM
Truck dying- fuel pump? Please help :) thaduke2003 5.9L V8 Specific Topics 17 03-23-2011 10:05 PM
2009 manual for a Quad cab 1500 truck Jack772 2009 Dodge Ram Forum 3 09-30-2009 11:11 PM
