Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 07-15-2011, 11:24 PM
Lifeisg Lifeisg is offline
Vehicle: 2004 Ram 2500
Trim Level: SLT 4x4 (Off Road)
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Lifeisg is on a distinguished road
Default XRF ball joints
My front tires are wearing unevenly, so I had the front end checked and turns out my ball joints are bad, and my shocks showed signs of seepage. I did a little research and decided to go with XRF brand ball joints with the million mile warranty. Lesson learned - don't buy them direct from the company, because you can find the full set much cheaper from vendors on the web.
If any of you have installed XRF joints, I'd be interested to know if you've had issues with them or satisfied with their quality/performance.
I also went with their sway bar links, and for the shocks Bilstein HD.
Lastly, I'm not planning to replace any other components, but I'm interested to know if you recommend any other preventive maintenance actions while I'm at it. Thanks in advance for your input.
Old 07-17-2011, 02:35 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 07-24-2011, 01:48 PM
jamesb0 jamesb0 is offline
Vehicle: 2006 Ram 2500 Quad/ SB / 4x4
Color: Flame red
Rep:57
jamesb0 will become famous soon enough
The U-joints are real crap in the 2500/3500 4X4. My front ones are on they way out. You should have AAM 9.25 14 bolt axles under your truck, they switch from Dana in 03 for the cheaper AAM units and that came alone with cheeper parts. You have to make sure you get the right ones there is a slight size difference in the U-Joints and allot of the parts store don't know this
Old 08-02-2011, 02:40 PM
ramjam04 ramjam04 is offline
Vehicle: 2004 Dodge Ram 1500 4x4 QC
Trim Level: Chrome
Color: Blue
ramjam04 is on a distinguished road
thought we were talking about ball joints
Old 08-03-2011, 06:07 AM
Color: Flame red
Rep:57
There is a slight size difference in the ball joints as well, compare to the Dana units
ball joint, shocks, sway bar link
question on Ball Joints JLash87 Suspension 9 02-15-2011 12:02 AM
Death wobble = axle swap fundaddy75 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 11-08-2010 10:50 PM
Ball joints? JOKER Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 5 04-17-2010 08:23 AM
Ball joints are done black beauty Drive Line 7 03-17-2010 07:11 PM
Ball joints black beauty Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 5 03-11-2010 05:39 PM
