Old 07-16-2011, 10:39 AM
GraceMartha GraceMartha is offline
Vehicle: 2008 Dodge Ram Laramie Edition
GraceMartha is on a distinguished road
Default Wrangler stock tires
Hi Everyone!
I have a 2008 Dodge Ram 1500 Laramie in red; I love it! My issue is that my tire pressure system light has come on, and will not go off. All of the tires have been checked multiple times (by me) using a tire gauge, and they are inflated properly---and none of them appear to have a side bubble that I have seen on some truck tires. They came stock with Wrangler HP P275/60R20 tires. I have 67,000 miles on the truck. Now because the light is on, and will not turn off, I have a couple of guy friends that have told me I need new tires, but my brother says I do not. Anyone else have the same problem with the tire light? Any suggestions would be helpful. I would love to get new tires, but of course would like to avoid the expense if possible. Also, if I do need new tires, should I get the same exact ones?? Thanks!!!
Old 07-16-2011, 04:34 PM
azram2011's Avatar
azram2011 azram2011 is offline
Vehicle: 2011 ram
Color: flame red
Rep:26
azram2011 is on a distinguished road
what tire pressure are you running ? could be bad sensors as far as tires just make sure there the same size brand does not matter
Old 07-16-2011, 07:17 PM
Tire pressure is 35, just like the manual says it should be. Do you think I should get new tires anyway because of my mileage? All of my miles are highway as I travel that way to my job. You are very sweet to answer, thank you!!!
Old 07-16-2011, 07:53 PM
azram2011's Avatar
Vehicle: 2011 ram
Color: flame red
Rep:26
i would try around 40 psi then drive a few miles to reset the censors 67000 is a lot of miles for a set of tires look in side the drivers door jam there should be a sticker with the tire presser on it try that do you have a read out for the tire presser monitor ?
Old 07-16-2011, 07:56 PM
Rep:2625
mileage only counts when you find by looking in between the tires treads
you will see wear bars, they are little raised areas, you can't miss them
take a penny, hold it so the Presidents head is upside down & facing you
follow these directions
http://www.nascar.com/2007/auto/cct/...est/index.html
Old 07-16-2011, 09:19 PM
azram2011's Avatar
Vehicle: 2011 ram
Color: flame red
Rep:26
i have 17" tires and run around 40 psi
Old 07-17-2011, 11:07 AM
Okay, I will raise it from 35 to 40; that's safe, right? As far as a read out for the tire pressure monitor, where would that be located? From what I know about this truck, I only have the dash light. After you indicated that 67,000 is a lot of miles for the tires, I am thinking I should just get new ones. Funny, I priced them through Goodyear tire centers, and none of the dealers around me stock them; Sears is the only one who does or my local Dodge dealer. Sears is less expensive than Dodge which doesn't surprise me for a second. Thanks, Guys!!!
Sue
Old 07-17-2011, 12:30 PM
azram2011's Avatar
Vehicle: 2011 ram
Color: flame red
Rep:26
Sue
yes it should be safe then drive it for a few miles to reset the sensors and see if the light go's out is there a tire shop near you ? let them check it for you might be bad sensors my truck is a 2011 with the read out
Old 07-17-2011, 01:22 PM
Wink
azram2011,
Thank you! Heading out in around an hour from now, and will do just what you suggested. Appreciate your help greatly.
Sue
Old 07-17-2011, 01:27 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
If you have good tread and no bulging you should be able to keep running with them. I would suspect that you have a bad sensor, which is why the light will not go out. As for replacement tires, there are much better choices out there. Don't just replace them with the same crappy stockers. Just my two cents............
Ram 1500 stock tires belle Dodge Ram Wheels And Tires 20 04-03-2012 09:05 PM
biggest tires stock 94 1500 94muddigger Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 05-15-2011 06:22 PM
305 tires on stock rims srtsir Dodge Ram Wheels And Tires 6 05-21-2010 02:19 AM
Biggest Tires on stock '04 1500 Ram Eng0270 Dodge Ram Wheels And Tires 1 10-16-2009 12:57 AM
08 ram 35" Tires on stock 20s leveled Husker1111 Dodge Ram Pictures - Photos 7 08-22-2009 08:20 PM
