blistein shocks for a mild lift? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-16-2011, 09:57 AM
Luke243 Luke243 is offline
Vehicle: 2004 Dodge Ram 1500
Luke243 is on a distinguished road
Default blistein shocks for a mild lift?
Can you really get 2.75 inches of lift from these shocks, or are they just for trucks with a lift already? OR is it just for a level? I think rancho offers something like this
Old 07-16-2011, 10:13 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
You can use the shock as a leveling kit. The have an adjustable retainer clip and usually have four height settings, depending on the truck 2.5" or 2.75" is usually the max height.
Unfortunately since your truck is an 04 you can't use these. Your truck has torsion bars so you can either just crank up the torsion bars for the little bit of height your looking for a little more height or you can buy new keys that will do the same thing.
I wouldn't recomend going much higher then +2" in the front if you choose the first option as it will stiffen up your ride alot past 2"
Old 07-16-2011, 10:24 AM
ok gotcha... what kinda shocks would you reccomend, ive got 81,000 on the truck and i was looking at maybe some skyjackers? or eldelbrock?
Old 07-16-2011, 10:47 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
You can still get Bilstein shocks. . I love mine !!
Old 07-16-2011, 10:57 AM
Color: Mineral Gray
Rep:177
If you have the money to spend, you can get a regular bilstien 5100 shock. I've heard nothing but good things about them other then how much they cost.
I just put Pro Comp ES9000 on all four corners of the 2500 and have to say that I am very pleased with them. I have a 2" Hell Bent Steel leveling kit on the front and the ride was a little rough with stock length shocks. The +2" shocks in the front made a HUGE differnce.
The truck rides like its stock now and the ES9000 didnt let the rear end sag at all with 6500lbs of stock trailer behind it (usually sag is alot worse on trucks that are leveled) and the ride was still comfortable
cst 7'' lift or billstein leveling shocks?? marshallsmith44 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 27 06-14-2011 08:36 AM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 11:25 PM
blistein 5100 shocks platinuminjected Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 12-28-2010 07:57 PM
Need Help with Shocks!!! jpaul51 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 12-05-2010 01:40 AM
