Old 07-16-2011, 01:16 PM
IvanSunn IvanSunn is offline
Vehicle: 1998 2500 Dodge Ram
Color: Brown
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
IvanSunn is on a distinguished road
Default 4 wheel drive engagement
1998 Ram 2500 4x4 with cummins.
Working on 4 wheel drive. Vacuum correct pressures at Axle shift motor. Removed motor, cleaned and checked shift folk for binding. Looked ok. Checked travel of shift motor shaft, again looked like it was ok. This is where I think the problem is. I could not move the shift colar over the intermediate shaft, from the passenger side axle shaft. It appeared to me to be a little lower. With the aid of a small pry bar, I lifted the passenger side axle shaft up, turned the passenger wheel a bit and the shift collar slide on without any trouble. Four wheel drive engaged and all wheels turned. Put everything back together and once on the ground, again could not engage the four wheel drive. I feel for sure the passenger side shaft being lower is my problem.
Has anyone else had this problem. I do not see any bearing or bushing that would hold the shaft in place.
Lastly, the passenger side wheel bearing recently went bad and I replace it. The four wheel would not engage prior to replacing the bearing.
Any help appreciated. Thanks
Old 07-18-2011, 09:47 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 03-08-2012, 08:27 PM
97ramrod's Avatar
97ramrod 97ramrod is offline
Vehicle: 1997 Dodge Ram 1500
Color: Maroon
97ramrod is on a distinguished road
im currently working on mine as i type with greasy fingers, there is a bearing holding the intermediate axle shaft. mine has gone out and i pulled the metal shards left of it out. go to quad4x4.com they have a polyurethane bushing i bought for 14bucks that is a replacement for the ball bearing. this way instead of the mud ruining the bearing the poly bearing will not be affected. my only problem now is i cant get the shaft disconnected from the diff. when i do ill let you know. so far this is relatively easy, im about an hour into it and two beers so id say so far an intermediate project.
If your not first, your last!!!
Old 03-08-2012, 09:58 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Try getting a pry bar or tire iron between the u joint and the rear yolk to pop it loose.
4x4, axle shift motor, indermediate shaft, shift collar
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
4 wheel drive notification lamp on dash jlive Body & Interior 17 02-23-2015 02:54 PM
Grinding noise in 4 wheel drive 03dodge4x4 Dodge Ram 4x4 - Offroad Discussion 2 12-13-2011 04:34 PM
4 Wheel Drive Issue. Need Help wadsworthdj1 Newbie Checkin! 14 06-03-2011 08:36 PM
HELP 4 wheel drive Bluebee 5.7L (345 cu in) HEMI V8 Specific Topics 12 12-30-2010 09:35 PM
